dbilas db Tronic 4500
  • fporro
    • 1860
    Decided to give dbilas dbTronic 4500 stand alone systems a try and can't find any reviews., I does cost more but it's suppost to be a perfect match for their itb systems, hopefully more user friendly than their installation procedure.
    It seems like it has everything an ITB system would need., could also be used on single TB systems with experimental plenums/runners/thrumpets, etc.
    Has TPS, MAP, barometer, a/N blend tables, ever important dataloging and flashing ?., timing and dwel manipulation, idle, boost, launch modes, etc, wondering if it still requires a/N 2000 control box, if so, maybe it can be fooled by W.A.R. system ? ...
    If you look under Performance kits on page 93 there's a
    Stage 2 m20b27 (stroker I think) that outperforms m20b25 stage 4 kit http://issuu.com/adocom/docs/dbilas_katalog_2011
    Both Performance kits include a/N 2000 controler, maybe I could recycle W.A.R. onto it instead (same thing I hope) that would be even more fun, 4 a/N tunes lol ... http://www.dbilas-shop.com/Products/...12V::6380.html
    Anyways, guess I had to rave now before I start ranting later on, lol. :)
    • 34844
    I have the feeling you can't use WAR with it.
    at 1250 euros.. man, there's a lot of great computers you could get. I'd bet both VEMS and MS3 would crush that thing for like $500 less.
    also it doesn't say anything about how many injection or ignition outputs it has. if it's still running batch injection and a single coil.. run away!
