MS2 reprogram?
  • F34R
    sLaughter
    • 12376
    MS2 reprogram?
    A member wants to trade a MS2 for my Schrick 288, it is setup for m20. How hard is it to get it to run my m30?
    Who do I send it to or is it easy enough to do on a laptop with a software download from MS?
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
  • IronFreak
    • Dec 2012
    • 3702
    I would send a PM to grsmonkey, He is a local guy that is an MS guru. He has built m20's, s5x motors all using custom tunes. He's doing all the setup, checking and programming for my build (I'm using MS2). He's not on here much but I can send him a text and have him respond to you. H'e currently doing a m50 turbo swap in his daily vert which I believe will be ran by MS as well.
    Instagram @rebellionforge
      • 34844
      the only difference between running an M20 and an M30 will be slight changes in fueling and possibly ignition timing. but basically, if you adjust the req_fuel for injector size and engine displacement, it should run as-is.
      • F34R
        sLaughter
        • 12376
        Picked up a MS2 from whodwho, he converted it and offered his skills in stock m30 management and again when I go turbo. Great guy :)
        Current cars:
        ~ '87 535
        ~ '06 X5 4.8is
