MegaSquirt power problem
  • Bmwb
    • Jan 2013
    • 196
    okay I got this thing running in my car but heres my issue , fuel pump runs while cranking rpms signal dose go up , im not getting any spark at all I tested it from the coil aswell no spark , runs with the old ecu so im thinking something's messed up with this , here are some pics yes its messy but everything's in order and in the right spot I used this write up... off diypnp
    The NEW full standalone AMP Play-N-Play ECU for the 1987-1993 BMW E30 / E32 / E34, installs for most in under an hour.
    Sold Black BMW E30 325IS
    1987 bmw e30 euro part out
    1990 Bmw 325i Cabrio 2.9
    Metric Mechanic 2.9 stroker
    Holset Hx35w CXRacing Manifold
    MegaSquirt ARP HeadStuds
    OEM HG AEM Methanol injection
    20psi
  • Bmwb
    • Jan 2013
    • 196
    Anyonee x/ this things being geyy
    Sent from my SGH-I747M using Tapatalk 2
    20psi
    • whodwho
      • Jun 2008
      • 1547
      It doesn't look like you have your ign jumpered
      Here are details of the ignition setup - http://www.diyautotune.com/diypnp/do...n_control.html
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • whodwho
        • Jun 2008
        • 1547
        also don't see a enabled jumper on the IAC circuit
        • Bmwb
          • Jan 2013
          • 196
          ye I realized this last night!!!! I forgot to jumper the damn thing I went over and over it and I figured it out I feel like an idiot lololol,. what do I jumper the iac circuit 2 it says the iac in but were the hell is that i see a bunch of (in) lol thanks my man
          20psi
          • whodwho
            • Jun 2008
            • 1547
            Main - Adapter
            IAT - 44
            IAC - IAC IN
            And under Notes 8^)
            IAC Open - Pin 4
            IAC Close - Pin 22
            • Bmwb
              • Jan 2013
              • 196
              okay car runs!! , now I got a problem the base map tune u gave me got it started im running bosch 19lb injectors... im getting raw fuel coming outa my exhaust and smoking up the place??? any ideas on wthhh is going on thanks this use to enver happen with these injectors until I fueled up and then idk wth happened , I might just go back to stock injectors until I turbo the car or get 17s , these are the one si got exactly
              http://www.ebay.com/itm/6-19-lb-Fuel...ccd557&vxp=mtr
              6 tested good used 19lb fuel injectors from V8.
              I have rebuilt them for years of trouble free performance. All have brand new pintle caps, upper/lower orings,spacers, and Filter baskets!
              1.These are an upgrade to the tiny 14.5 lb stock units in the M20 B25.
              2.Upgrade to M50 injectors since they flow 17.5 lbs
              3.Also serve as a small step up for M30 B35 liter engines.
              4.They drop right in with not modifications to rail or harness.These are a great upgrade because they flow much more and are 4 pintle not 1 for better fuel atomization.
              Flow 19lbs @38 psi or 20.3 lbs @43.5 psi. or 21.9 lbs @50.7
              43.5 psi is what most 80s BMWs run at.
              50.7 psi is what most 90s BMW run at
              Bosch Design III 4 pintle
              20psi
              • Bmwb
                • Jan 2013
                • 196
                It was the spark plugs I had some crappy ones I took out my 19s for nothing.. and my cars giveing ereor code 1222 with the stock ecu whodwho got any stock tunes everything is basically running good on the stock tune wanna get it running for a few before I start upgradea
                20psi
