Wiring in Map Sensor--(Goathumper?) v3.0 ms2 pnp
  • kistler#7
    • Jun 2013
    • 186
    I am trying to wire in my GM Map sensor--v3.0 ms2 in 55 pin case, pnp built by Goathumper(?). Megamanual says to wire gm map sensors into pin #1 (the square pin) in the map sensor input, thats centered in the pic below
    On the other side the wire soldered in:
    Which goes across the board and enters the bundle on the bottom side:
    Or right side as pictured here:
    And into this connector, 5th from the right
    And then where? It goes 'underground', do any megasquirt (or motronic?) geeks know where the wire goes, or to which pin in the 55 pin terminal?
    Last edited by kistler#7; 01-15-2014, 10:37 AM. Reason: Not built by Whodwho, (Goathumper?)
    m20b27 Turbo. Hx35. Twinscroll Mani. MS1. 42lbers
    http://www.r3vlimited.com/board/showthread.php?t=338818
  • whodwho
    • Jun 2008
    • 1547
    Definitely not one of mine, looks like an old Goathumper one
    You should be able to remove the jumper wire for the one that is soldered in(the map sensor must be on the adapter board) and solder your connection as mentioned in the manual
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • kistler#7
      • Jun 2013
      • 186
      Ok thanks for the help. Hopefully next post is a startup vid
