Megasquirt tune sharing
  • jules325i
    • Jul 2011
    • 353
    Im getting a PNP megasquirt system shortly for a stroker im building.
    I would like to know if anyone is willing to give me or sell me there tuned stroker tune.
    That is similar to my setup.
    Im going down this route because where i live in australia its hard finding someone willing to tune with megasquirt on the dyno.
    The Setup
    2.8
    11:1 comp
    885 Head
    288 cam
    Extensive headwork
    329i
  • jules325i
    • Jul 2011
    • 353
    Bump
    329i
    • FLG
      • Sep 2011
      • 3165
      Besides a base your gonna need it tuned on a dyno. I don't see why you'd have problems finding a tuner? Generally the way they tune it is all the same regardless of software. It might be a bit different layout then some are used to but it's all adjusting the same parameters
      Sent from my SCH-I545 using Tapatalk 2
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • george graves
        • 20003
        Ummmm. I'd get a tune that gets you up and running (or even starting) - and then butt-dyno tune it with a wideband and a laptop. Most* people don't dyno their cars to get MS running well.
        Originally posted by Matt-B
        • Ether-D
          • Sep 2011
          • 2838
          Tuning is so overwhelming at first. If you do go the "butt dyno" route, get "Engine Management Advanced Tuning" by Gregg Banish. It was suggested to me and it really cleared up a ton of the mystery. It's like $10 for an "e-reader" version on amazon.
          And people hoard their tunes like a squirrel hoards his nuts.
          Originally posted by Andy.B
          I was born on 3/25…
          • FLG
            • Sep 2011
            • 3165
            Better safe then sorry. I'd always have a pro tune rather then trust myself. Especially on a non stock engine.
              • 34847
              I've always shared my tunes. they've been located in the same place for 7+ years.
              the problem with sharing tunes is that the firmware constantly evolves. you can't just take my exact file and load it into your MS and expect it to work. I haven't used MS2 for example since 2010 - you wouldn't want to copy everything over verbatim because you're using 2014 firmware. My MS3 tune is over 2 years old already. I don't keep up with firmware flashes since an incident in the parking lot at work a few years ago. :p
              lucky in the latest TS versions you can load just parts of a tune, for example, the spark and fuel maps, etc. but that only gets you so far.
              also, most tunes that I've seen have settings that are just plain wrong. people don't understand what most of it does.. all they know is that the spark table controls ignition and the fuel table makes their AFR gauge change. They have no idea of the meaning for the tooth #1 angle or how to find it, how the startup maps interact, how a PID loop works, etc. Copy somebody else's tune at your own peril. chances are you'll be fixing something that they did wrong, that's if you can understand it well enough to figure it out on your own. some of it will just be annoying, other issues can actually cause damage (dwell settings, as an example).
              basically what I'm saying is you need to understand how all of it works. if you want to just drop a non-running car off at a shop and expect them to figure it out, that will be very costly. few shops know much beyond ignition and fuel maps either, they'd be no better off than you in trying to figure it out, except they're charging you money.
              you can get specific answers to specific questions. taking a shotgun approach "my MS doesn't work" isn't going to get you far because that could mean a million different things..
              • Ether-D
                • Sep 2011
                • 2838
                And most people hoard their tunes like a squirrel hoards his nuts.
                ftfmyself
                I was born on 3/25…
                • jules325i
                  • Jul 2011
                  • 353
                  In my area People don't know or want to tune with megasquirt and i don't feel i want to take it on, great infomation input tho guys thank you.
                  I think im going to buy A Wolf ECU Because i can get it professionally tuned close by.
                  329i
