Tach Wiring -Megasquirt/Wasted Spark
  • JCarp90
    • Feb 2011
    • 1759
    Hi guys -
    I have a question for you all. My car does not have a stock cluster so I'm using an Autometer Tach. The tach used to pull signal from the ground side of the ignition coil, but I recently converted to wasted spark, so no more coil. How would you go about wiring the tach?
    Thanks
  • jperris
    • Feb 2014
    • 31
    Your ECU outputs an engine speed signal on pin 6. If the stock cluster wiring is intact, it should go to pin 7 (black wire) of the 26-pin blue instrument cluster connector.
    edit: just noticed your post title suggests Megasquirt. Doesn't the MS control unit have a tach output?
    2nd edit: ....and now I see a mod has moved your thread from gen tech to the alt tuning forum. i'm outta here.
    1989 Bronzit 325i
    • JCarp90
      • Feb 2011
      • 1759
      That was what I planned on doing, but I don't have any of the original harness still in the car. Everything has been re-wired. I was advised to splice into the RPM signal into the DME, but that didn't register anything at all.
      I'm not sure why my thread was moved, it's not really related to tuning/MS.
      • whodwho
        • Jun 2008
        • 1547
        It should of worked from the tach out on the ECU but you can still drive it from the coils like this
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
        • JCarp90
          • Feb 2011
          • 1759
          Good deal. I'll give this a shot.
          As always, Whodowho saves the day.
            • 34847
            MS2 and 3 have a tachout pin. that's a lot simpler than a bunch of extra hardware. all you need to do is jumper the tachout header on the board to one of the spare pins on the DB37, turn it on in tunerstudio, and plug it into your tach.
            you can't hook the crank sensor to the tach, which is what I think you were saying in your other post.
            • Jaxx_
              • Dec 2009
              • 1880
              this. I run a megasquirt tachout to a crappy autometer tach and it works just fine. you might have to do a few small mods on your megasquirt board. The information is on the msextra site concerning the different tachout setups:
