Hey guys I was wondering what kind of diverter valve you guys are running on your turbo set ups
miller War chip
Tags: None
Are you refering to a wastegate or blow off valve?
Sent from my SPH-L710 using Tapatalk
m20b27 Turbo. Hx35. Twinscroll Mani. MS1. 42lbers
http://www.r3vlimited.com/board/showthread.php?t=338818 -
While I don't run the WAR chip, I always prefer venting on the hot side to atmosphere. Sure you run a bit rich, but it makes the most sense in my opinion. Better than venting on the cold side, or even recirculating with a DV to the intake again just to be compressed again by the turbo and heat up more.
This argument also depends on where you are metering the air.'84 318i M10B18 147- Safari Beige
Turbo: 221whp/214ftlbs, MS3x flex @ 17psiComment
