84 325e not chippable?
  • HennaE30
    • Apr 2014
    • 1965
    So I was driving around rather aggressively today, and I was taking it to what I thought was the redline (4800rpm). Each time I went a little further and a little further and still no rev limiter. So I rev'd it till it hit the limiter, which was off the tac (around the 5500-6k range if I had to guess).
    So I decided to open up my ECU to check if it was chipped, and both sides of the ECU have boards that don't (seem to) come out.
    Are the 84 325e's (Bosch 1 708 643.9 ECU) not chippable? If they are, what am I missing? I was being careful not to bend/break the boards when I tried to see if they'd come out.
    Also If you cant chip one is it possible that its just a tune someone ran on the stock computer?
    Originally posted by flyboyx
    how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
    Originally posted by Northern
    beer is my new liver cleanse.
    Henna - '84 Hennarot 325e
    Lola - '89 Schwarz 325is - being saved
    Christine - '88 Schwarz 325is - Spec E30 Racecar
    '01 White F150 Lariat 4x4 Supercrew - Daily
    Dad's '05 Interlagosblau M3
  • reelizmpro
    • 9552
    Should have a soldered chip.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • HennaE30
      • Apr 2014
      • 1965
      Do the boards come out? And if the chip most likely isn't swapped, could it be tune
      • reelizmpro
        • 9552
        Only one needs to come out... If the chip is soldered, it needs to be desoldered, tuned/rewritten and resoldered OR have a socket installed. Most people will just swap to a later style DME with socketed eprom chip instead.
        88 M3 - LACHSSILBER
        • HennaE30
          • Apr 2014
          • 1965
          I know that, but I didn't want to apply any force to getting either of them out because I didn't want to risk bending or breaking them, if neither were supposed to come out. I think I've figured out how to get it apart but wanted to wait for confirmation before trying.
          Edit: the one to look at is the one with the white sticker, correct?
          • reelizmpro
            • 9552
            Well that picture should tell you what you need to know. Unclip the end opposite of the ribbon cable. Of course you always risk breaking something especially since they are so old now. Just be careful.
            88 M3 - LACHSSILBER
            • HennaE30
              • Apr 2014
              • 1965
              That I will be, I'll pull it apart again tomorrow once I get to see if I can figure it out. Thanks for the help.
              • reelizmpro
                • 9552
                Yes, the white/silver sticker eprom with the numbers on it contains the ignition/fuel maps.
                88 M3 - LACHSSILBER
