I am hoping to get some help here. I am trying to finish up a turbo e30 project I have had going on for a while now. I am fighting synch loss in the higher RPMs and I'm not sure why. I swapped it over to a Hall Effect sensor that diyautotune sells from the stock VR sensor an I am still having issues. I have a short log I attached from driving it earlier. If anyone has any ideas I still have the megasquirt wired up for the VR sensor on the board, would that cause any issues with the hall effect? Would adjusting the pots do anything? Is it a tooth #1 angle setting I maybe have wrong? I'm really looking for any ideas because it is the last thing holding me back.
Synch Loss Issue 2
Tags: None
double check clearance between the pickup wheel and the sensor. I do believe that Hall and VR have different board wiring, but it should all be listed in the megamanual.'84 318i M10B18 147- Safari Beige
