Siemens 60 lb/hr Injector dead time help
  • nomansland92
    • 1657
    I know these are a popular injector around here and but i cant seem to find a solid number to go from for tunerstudio.
    Turner studio suggests it should be .7ms to .9ms but the only info i could find is saying there roughly .36ms- 40ms.
    Is that actually correct, that just seams way to fast.
    http://www.fiveomotorsport.com/107961-siemens-60lbs
    I seen here someone had luck running them at .75ms
    So for anyone using these injectors what dead time are you using? i would like to figure this out before i continue tuning then have to redo everything over one setting.
    Thanks, Stevan
    IX being restored here
    Ix turbo build here
  • shadowracer
    • 253
    Not sure of your set up but, I'm running mine at 13.2volts 1.000ms with battery voltage correction (ms/v) at 0.200
    • nomansland92
      • 1657
      Ok thanks for the reply, I'll switch it to that for tuning tomorrow. I wish I would have just tested them before I put them in but I didn't even realize I needed to adjust for that haha, still learning about tuning here
      Ix turbo build here
