84 m10b18 NA Base tune anyone?
  • Whit3 E30
    • Dec 2013
    • 142
    Hello fellow r3v people, I am just starting to tune my rebuilt m10b18 which is naturally aspirated with a 292 cam n bigger valves. I put a new high pressure fuel pump n have green top injectors from a 91 325i m20, along with the pressure regulator from a m20. I am running the ms 1 with the 3.0v motherboard and it will be running my ignition coil also. I am wondering if anyone has a good tested base tune? So that I can have to start off on the right foot. I would really appreciate any ones base tune for fuel mapping and ignition control. Thanks to all and hope this thread fills up fast with responses:D
  • Kershaw
    • 11822
    greentops are from an m50 (17lbs), bluetops (14.5lbs) are from an m20. IIRC.
    AWD > RWD
    • thebutterson
      • 463
      I have one for my stock 318i that I've been modifying based on a tune from a guy on 2002faq. Is there a trick to posting a .msq on here or do people just upload screen shots?
      • Whit3 E30
        • Dec 2013
        • 142
        My b you are correct I didn't proof read, I meant blue tops
        • Whit3 E30
          • Dec 2013
          • 142
          Idk how to send msq on here but pm me n I'll give you my email or something
          • Jaxx_
            • Dec 2009
            • 1880
            I uploaded my tune for Whit3 E30, you can find it here:
            a few notes:
            -factory motor with no idle air controller
            -EDIS coil driven directly with MS2
            -LC/2-step/Flatshift configured
            -Fan out relay trigger
            -315 CC/min injectors
            -street tuned (ignition map is not on the ragged edge, but feel free to take out a few deg to make it safer)
            -made 93whp/90ft lbs with cat-back, AFM/AC/PS/clutch fan delete, 3.73 in 4th (1:1)
            Probably a few more gotchas in there, but that's the main configuration I have.
            • Whit3 E30
              • Dec 2013
              • 142
              Bump
