Hey Guys,
I have an M50 TPS and am now running MS2 from whodwho. He explained to me that you need to switch two wires on the plug. I'm pretty sure I switched the wrong wires. Do any of you know the color codes of the wires that are supposed to be changed for this application. I know they are all a brown variation. Want to complete the right switch tonight so any help would be appreciated. I'm currently using the stock e30 plug which work with this but the wires need to be swapped with his application. I also already have the correct adapter in pace as well.
Thanks
Thanks
