Originally posted by Jaxx_
View Post
Megasquirt Timing and Fuel Map Thread
Originally posted by Jaxx_ View PostYour fuel table looks very... Unpolished. What are you boost targets? 8psi? And boost cut at 21psi?
I get what your saying. I guess I better get a log for everyone to review. I could ask the tuner to send one over if he still has it. would it matter if we only tuned it to 8psi, hence the matching cells above that range?
sorry if this is a bit much on the questions. just trying to understand better
Originally posted by Digitalwave View PostIt'd say it looks *too* polished. Doesn't look like real world numbers. Too smooth and too many matching cells.
Pulling a few degrees is not going to hurt anything. I just don't see your fuel table as being safe if it is so flat. If it was tuned on a steady state dyno the ignition map is probably close, but changing the fuel table will have an effect on optimal ignition values. You should try to see a log with that tune and see if AFRs look safe.
You only need 1 or 2 extra rows of fuel and spark tables to have coverage for over boost. The fact your overboost trigger is at 21psi worries me. Set it to like 12.'84 318i M10B18 147- Safari Beige
Also save the .MSQ (tune). You can upload them onto Google docs and share them here.'84 318i M10B18 147- Safari Beige
Perhaps try uploading the log to datazap.me? I don't know if it'll support MSL—if it doesn't you could attempt to change the file name to .CSV. worst case, you can email it and I'll host it'84 318i M10B18 147- Safari Beige
I haven't looked at them yet, but here are turbski's MSQ and logs.
