How to add Cam Position Sensor to WHODWHO MS2PNP with wasted spark
  • dirtyEthirtyIX
    • Apr 2017
    • 123
    I wondering how to add a CPS to my build. I have wasted spark setup and a Distributor block off plate with CPS from MRT, which is sold through BimmerHeads.com Do I remove the crank position sensor and wire in the new CPS or do I run them in tandem? If so, where on the board should i wire in the signal from the new CPS?
  • digger
    • Nov 2005
    • 6212
    you can get dizzy blockoff plates that will accept a cam sensor (or modify yours) and add a single tooth on the rotor adapter. you use both the original Crank sensor and a cam sensor
    • dirtyEthirtyIX
      • Apr 2017
      • 123
      i have the block off plate, trigger wheel, and sensor, i just cant seem to find how wire it in to my mspnp2. thanks for the info about running them in tandem. this my first time using a standalone ecu so i have to overcome the slight learning curve. I appreciate the help.
      • fergie
        • Jun 2017
        • 21
        on the MSPNP2 made by diyautotune the cam sensor simply wires into the 26 pin connector. the cam sensor input is pin 1. Im not sure id whodwho has the same pin out for the 26 pin connector.
        • kyleconstantine
          • Apr 2014
          • 1380
          The whodwho plug and play is based off microsquirt... check this link
          https://www.diyautotune.com/support/...n-control/#cam It seems to explain how to wire it in although I'll admit I'm not too familiar with microsquirt. I'd try to get in touch with whodwho and ask him directly before making any changes.
