Wasted Spark Wiring and Cam Position Sensor
  • Doorgoo
    • Jul 2012
    • 31
    Hey everyone, I'm looking for some advice on my WhodWho PNP E30 setup in preparation for twin turbos. For my wasted spark, how thick must the wires be? I have a DB15 cable that I'd like to be able to use for clean installation, but I'm worried that they are too thin of inner wires. If I need pretty thick wires, I'd appreciate a suggestion for a cable. Second, I want to run a camshaft position sensor and was wondering how to wire it in, or can I just use the pulse sensor connector? Thanks all!
  • kyleconstantine
    • Apr 2014
    • 1380
    Hey the regular megasquirt or bmw harness wires are fine to run your megasquirt. I cant seem to find what gauge they are but im using them on my dd with no problem...i havent set up a cam sensor but i read there is a spot in microsquirt to wire it up...i would try to ask whodwho directly if he left a spot in the harness to wire it in. And dont forget to let us know what you find.
    • Doorgoo
      • Jul 2012
      • 31
      Thanks for your reply, I already have my car running on Megasquirt. Just curious as to the ideal Wasted Spark wiring and the best way to connect a Cam position sensor to Whodwho's setup. I emailed him, no response but it is close to the holidays.
        • 34839
        you don't need a cam sensor for wasted spark. it's only needed for sequential fuel or COP.
