Possible Variable TPS issue in Megasquirt
  • E30RoadKing
    • Sep 2015
    • 51
    I have an E36 throttle position sensor wired into my E30 wiring harness. At closed throttle, Megasquirt reads 0%, and at wide open, it reads 100%.
    The problem is that when I hit the gas pedal, it doesn't go through the whole range to get there. It might read no change, then all of a sudden 30%, then no change until 70%, then no change until 100%. However, when I let off the pedal, it reads pretty much every percent until it goes back to 0%.
    Is this an issue?
    1969 Chevrolet El Camino - SOLD
    1979 BMW 320i - Traded
    1980 BMW 633CSi - SOLD
    1986 Chevrolet K30 Silverado - SOLD
    1987 BMW 325es - Totaled
    1987 BMW 325ic - Traded
    1990 BMW 325is - First car/Sunday Cruiser
    2004 BMW 325xi - Totaled
    2007 BMW 335i vert - Traded
    2018 Chevrolet Cruze - Totaled
    2019 Subaru Impreza
    1980 Suzuki GS850 - SOLD
    2004 Harley Davidson Softail - Traded
    2007 Suzuki GZ250 - SOLD
    https://www.flickr.com/photos/155574105@N08/albums
  • Jaxx_
    • Dec 2009
    • 1880
    It will be hard to setup accel enrichment and other tables based on TPS. I would investigate further if you are interesting in having a TPS for these types of functions. If you simply want flood clear to function, don't worry about it.
    I don't know much about E36 TPSs, but I would confirm with a multimeter that you have the right pins wired to megasquirt
    • digger
      • Nov 2005
      • 6201
      is the sensor new?
      • justinpirie
        • Feb 2014
        • 111
        Originally posted by digger
        is the sensor new?
        I would guess the potentiometer in it is broken. Grab another sensor? It should move smoothly.
        • ak-
          • 12422
          Mine did this when it took a shit. Get a new TPS. Car would always die at a stop as well.
          1991 325iS turbo
          • E30RoadKing
            • Sep 2015
            • 51
            Ended up getting it tuned with no problem. Sensor was new/OEM from the dealer, and just in case I had it replaced with another new OEM one.
            Tuned using alpha-N due to ITBs.
            2019 Subaru Impreza
