Well im doing a job on my boys white e30 but its choking i think its the 02 sensor if the o2 sensor bad what dose it affect and how
Help car choking
Pretty vague explanation of your problem. Under what condition does the "choking" occur? Under acceleration, cruising, wide open throttle?
You can easily test the O2 sensor and it's plug with a volt meter if you think that's the problem.| Jimmy | 1999 M3 | 1986 325 ES |Comment
all 3 but mainly cruising and accelerationComment
OK U need do stuff 2 fix it
That is what i get, when I read what you have written. Have you not completed primary education? It is hard for me to take you seriously when you write things like your previous statement. A detailed explanation of what happens, with correct spelling and punctuation, would help anyone reading your thread, help you.
About how long into your "cruising" does this happen?-tim
-Coining hip terms since 10/9/03Originally posted by JordanI like the stanceComment
well when the idle goes low it doss it but after its up it wont do it any more
its sound like it needs gas when it doesn'tComment
