Help picking a cat converter
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    I need to get an exhaust setup for the m30 swap. I'm pretty settled on a Dynomax VT 2.5" single muffler, the sound flap thing is way cool IMO and will fit the character i'm going for for the car. But I need a converter. Searching Summit for a 2.5" single outlet I get like 70 results, all about the same price ($70-90). So what the heck makes them all different? Is there a brand I should go with? Also, anyone know if it would be cheaper to fab the 2 stock downpipes as duals in to a dual-in, single-out cat or to merge the pipes and then travel in to a single-in, single-out cat? Thanks guys!
    • 34844
    http://www.summitracing.com/search/P...500-in/?page=1
    you don't need one with the air tube (those are for cars with dual O2 sensors), but I would reccomend not buying a cheap ceramic core cat. magnaflow makes a metal core version, you can also get a metal core from vibrant but it's probably a lot more expensive.
    • FredK
      • 14762
      I would get a Magnaflow 59926 2.5" I/O metallic substrate cat. It has proven flow numbers, and IIRC is a 300 cell per square inch cat for decent sniff test results (if you need to pass them), and it's around $105.
      I believe the Arvin Meritor Metal'Cat (not to be confused with the Metalcat from Australia) is a 200 cpsi cat, but I've forgotten if that's true or not. I run a 2.5" I/O AM Metal'cat.
        • 34844
        and FredK comes to the rescue with a part#. thanks Fred!
        what really sucks are the metal core cats cost $10 more than the ceramic one I got. doh!
        • CorvallisBMW
          • 13039
          Awesome, thanks Fred!
