I was wondering if an exhaust system from an ///M3 will bolt up to a 325is. Its the full cat back system. If it wouldnt bolt up I would imagine it could be cut and welded to the 325is pipes. Am I correct? Thanks
Exhaust question
Tags: None
I don't THINK it is that easy. You will have to do a bit more research on the two, but I think there is enough difference between them, that your idea is not feasible. I think I know why you ask this question ;), but you would be better served, imo, to purchase a system built for your car.
[THE 501 club - Founding Member] -
Originally posted by rcwellsI don't THINK it is that easy. You will have to do a bit more research on the two, but I think there is enough difference between them, that your idea is not feasible. I think I know why you ask this question ;), but you would be better served, imo, to purchase a system built for your car.
Thanks for your input but I still dont have the answer I need. I would lke to know if the pipes are the same size. If they are then I dont see why the pipes cant be cut and mated together. There is a badass ///M3 exhaust system for sale and my muffler is dead so I need a new one. This one would make a great replacement. So yes or no peeps. I just need one more person to tell me know and Ill go buy a damn 325is muffler :?
So call up the manufacturer (SUPERSPRINT) and ask them what diameter the system tubing is. Measure your own and you will have your answer. Actually I was referring to the way the systems are run underneath the car as well. I don't think they are compatible in their layout. I understand what you are asking but I don't think it's going to work.
[THE 501 club - Founding Member]Comment
Thats all I needed to here. ThanksOriginally posted by rcwellsSo call up the manufacturer (SUPERSPRINT) and ask them what diameter the system tubing is. Measure your own and you will have your answer. Actually I was referring to the way the systems are run underneath the car as well. I don't think they are compatible in their layout. I understand what you are asking but I don't think it's going to work.
