Do I need o2 sesonsor?
  • devon.818
    • Feb 2011
    • 2937
    At exhaust shop now.
    Running eBay headers to straight pipes. No room for sensor.
    I have miller MAF and chip to run MAF. Do I need the sensor? Will it b ok without?
  • devon.818
    • Feb 2011
    • 2937
    car runs. check engine light is on.
    gonna make the o2 sensor wires longer then have a bung put in my X pipe.
    • 325ix
      • Aug 2009
      • 7783
      It runs in closed loop mode without the o2 sensor, so yes you need it.
      • devon.818
        • Feb 2011
        • 2937
        what does closed loop mode mean????
        • devon.818
          • Feb 2011
          • 2937
          good time to install a wideband o2 sensor then?
            • 34827
            you mean open loop ;)
            you can drive to the exhaust shop without an O2 sensor. just go easy on it.
            you can't run a wideband sensor into a stock ECU, either..
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              I'd be looking for C8H18 sensor if I were you.
              • devon.818
                • Feb 2011
                • 2937
                got it hooked back up. it was running really rich, turning my headers a blue tint.
                that is starting to go away.
                better gas milleage with it in too lol.
                thanks guys.
                • 325ix
                  • Aug 2009
                  • 7783
                  Thanks, I have trouble remembering the difference sometimes.
                  • AirplaneBuilder
                    • 823
                    How would you make the sensor wires longer, what type of wire can I use? I been driving without a sensor for some time now, my odometer is broken and I don't use car as daily so I have no idea if I'm using more gas but it does smell much richer. Plus I need to pass smog test and they won't let me test with check engine light on. Anyone please help, I need my car ready for the leavenworth drive and e30 picnic! Thanks!
                    1989 Zinno 325i S50 ZF320
                    • devon.818
                      • Feb 2011
                      • 2937
                      i ended up just moving my bung for the o2 sensor. easier that way.
                      the o2 sensor only had like 3 or 4 wires. what you would do is remove some heat wrap close to the femal plug, cut the wires, add more wire in and solder and heat shrink over that. then re-wrap the wires in heat wrap.
                      they are color'd wires so it should be pretty easy.
                        • 34827
                        the O2 sensor wires are made of stainless steel.. you can't solder them.
                        • devon.818
                          • Feb 2011
                          • 2937
                          then use the electrical caps and electrical tape. or terminal connectors.
                          • AirplaneBuilder
                            • 823
                            So the extra wiring I get must be stainless steel wiring, some guy told me I could use any wiring as long as its same gauge. I'll use wire nuts, electrical tape and heat wrapping to connect everything.
