Side exit exhaust.
  • Operator62
    • Jul 2005
    • 119
    Side exit exhaust.
    Any opinions or tips on doing this? Just kind of looking at ideas for hangers really.
  • permit
    • Mar 2005
    • 3363
    That idea is more gangster than this guys thread:
    • 325Projectz
      • Jan 2005
      • 1956
      Someone has done it already and it was OK only because it was a drag/show car, otherwise rear exit.
      91 m3
      • ragehardintothebendies
        • 50
        Will be doing a side exit on my track rat, will probabley be going with a fuel cell so will have more mounting options one the OE tank is gone.
        If you have an I and you want it to exit on the drivers side I think you would have to relocate the fuel filter.
        www.islandmma.com
        • Digitalwave
          is a poseur
          • 6298
          Why would you want to do this? E30's aren't Roush Mustangs.
          RISING EDGE
          • joshh
            • Aug 2004
            • 6195
            I have a side exit on my Integra and finally decided that the only way its going to look good is if you can't see the exhaust at all. So it ends infront of the right rear tire and you have to lay down to see it.
            Good luck.
            "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
            ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
            • King Luis
              • Sep 2004
              • 737
              i think you should only doing if you need the exhaust coming out quickly....ie:turbo with huge power and or drag car. other wise it's not needed.
              • arsevader
                • May 2005
                • 1025
                One of the reasons people do this on a track car is to avoid the sound regulations that are in place.
                Most tracks measure the sound on one side (the outside) so if your exhaust is on the inside you can get away with a louder exhaust.
                James
                • Operator62
                  • Jul 2005
                  • 119
                  My reasons for doing a side exit are: Less weight because of less piping having to be used, cheaper, always liked the look of a side exit exhaust, and it's annoying to have to remove the exhaust everytime the tranny or driveshaft has to be removed. I know a lot of people won't like it, but I'm not really concerned too much about others liking it. Just wondering if anyone had some ideas for hanging it?
                  • DanGillan
                    • Mar 2004
                    • 4061
                    bring it to an exhaust shop, tell them what you want. pay. it will be done well. no need to ask any questions. it will be cool, just tell a shop what you want, do it, post pictures.
                    Dan
                    • el_4ever
                      • 145
                      ...sooo...it's a bad idea for EVERYONE to do their own work...i see
                      • guywithFX
                        • Nov 2004
                        • 91
                        i may sound like an idiot for asking, but i have seen it both ways...where would you locate the exhaust tips? i'm guessing thru a hole in the sideskirts but would you put the whole in the front or rear of the sideskirt? i've always wanted a side exit exhaust on an e30 but i don't know what would look better...front or back of sideskirt? hmmm o the possibilities :)
                        Nick Blake
                        R.I.P. - '86 Bronzitbeige 325eS
                        SOLD - 92 Boston Green 325i Sedan - Previous Daily Driver
                        Current - 2002 WRX Wagon - E85 Tuned @ 265/304
                        • 808BMW
                          • 2910
                          Good luck having it come out the front, it'll get crushed under your framerail the first time you go over a speedbump
                          • Old'n'Slow
                            • 436
                            Nooo. That's not what he's saying.
                            Since this is something that not many e30 guys do, and involves fabricating hangers and bending pipes, it involves a level of complexity that can result in a high frustration factor. Unless you are a competent welder and have metal cutting and bending tools or unlimited time to pfutz around, this is a job best left to someone who does it all the time.
                            The biggest problem with side exit is noises associated with pipes touching the body anywhere. You also have to allow for expansion with the mounting system or the welds won't hold. Also, having pipes so close to the ground on a lowered car risks crushed pipes.
                            I don't understand the rationale of "it takes too long to drop the exhaust so I'm going to spend lots of time and/or money to improve access to the driveline." With air tools, dropping the rear of the exhaust takes less than 10 minutes tops. Frankly, I don't disassemble the exhaust when working on the driveline. I just drop it down a few inches. Replaced diff and driveshaft in this manner!
                            • 02stu
                              • Jan 2005
                              • 872
                              I put side exit exhaust on my 02 for a little while and it had a couple problems. The first issue was every one that got out of the car got burned, all part of the 02 experience though. The biggest problem, like oldnslow said was that the exhuast hit the bottom of the car which made a horrable sound and was almost impossable to get ride of. Good luck though, if want a side exit exhaust go for it, you can always take it off.
