N/A to F/I Exhaust.
  • SwiftE30
    • Jun 2010
    • 998
    N/A to F/I Exhaust.
    So i am at the point where i need to buy a full exhaust setup for my s52 e30. I want to get the car running when it is N/A, make sure everything is running right and smooth before i jump into the turbo build.
    I have the Good&Tight turbo manifold and downpipe already.
    My question is, what should i take into account when looking for an exhaust setup that will work fine for N/A, but also be good for airflow when i switch to F/I?
    i can pick up a set of OBD1 headers from the JY no problem, btw.
    I am thinking stromung muffler for sound, but dont really know what i should be looking at for a cat, or if i should go single to dual before cats, or stay single throughout. etc. etc.
    Any suggestion is greatly appreciated.
    I have about $800 for budget.
    1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
    • 34839
    if you use real headers (not OEM manifolds, they're not headers), go with 3" single exhaust with a Y-merge. /done
    • SwiftE30
      • Jun 2010
      • 998
      oh ok, some ebay cheapy headers?
      so... Y merge the headers---> to single 3" --> to muffler (single inlet)
      no cat? wont that be difficult to pass emmisions then?
      thanks.
      edit: then once i switch over to F/I i can cut the pipes after the Y and have a pipe fabbed to hook up with the Good&Tight downpipe. Right?
        • 34839
        you could run a cat, like a metal core from vibrant. it really won't restrict anything with 3" tubing. ebay headers would be fine since they're temp. I'd couple it with 2 straight through mufflers, or 1 straight through muffler and a cherry bomb, to keep the sound sane while N/A. when you go turbo you can remove one of the mufflers since the turbo acts like a muffler already.
        that's basically the plan i went with except I'm coupling the 3" exhaust with something else instead of a turbo. :p
        dynoed vs my previous exhaust (stock M20B25 cat, SS catback), the 3" didn't lose any torque at all because I coupled it with RD headers and a Y-merge ~18" from the collectors. With manifolds there's no real scavenging so you don't get any benefit from the larger exhaust.
        • SwiftE30
          • Jun 2010
          • 998
          when you say two stright through mufflers are you suggesting i have them in consecutive order, one right after the other? I'm confused with this style. I am only familiar with cat--> to muffler where the muffler is basically at the very back. where would both these straight mufflers go?
          Sorry if these are retarted questions. I am very new to researching about exhaust systems and want to make sure i get the right setup first time around.
          i like the idea of a Y-merge 18" after collectors. The sound doesnt need to be sane at all while running the N/A setup because its only going to be for about a month or so. My neighbors will have to put up with it. :)
          from this i think i am going to go with...
          longtube headers--> Y-Merg --> metal core cat--> stromung muffler.
          what about dual all the way back, running dual metal cores into a dual inlet/outlet muffler? kind of like post #2 in this thread
            • 34839
            Dual costs and weighs more. Single is where its at, esp. turbo.
            • SwiftE30
              • Jun 2010
              • 998
              thats a huge bummer because from what I have been seeing/hearing on the forums for swapped 24v e30's and even regular e36 with exhaust i like the Stromung sound the best, and it is dual in/out.
              Any suggestions on what i should be looking for for single inlet setups? ....for future turbo setup.
              thanks
                • 34839
                being turbo it isn't going to sound anything like those cars anyway
                IMO, the sound difference really isn't there, it's merged before the cat section on the stock exhaust anyway.
                I like dynomax and borla, others may have different opinions.
                  • 37829
                  If you're going turbo you're likely not going to be passing any emissions tests anyway... ;)
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                    • 34839
                    oh yeah, as far as fitting 2 mufflers and a cat - the cat and muffler go where the old cat used to be (the stock cat/resonator is HUGE, there's plenty of room) and the 2nd muffler goes where the stock muffler was. if I can do it with a transfercase in the way I don't see the problem for a RWD car.. :)
                    • SwiftE30
                      • Jun 2010
                      • 998
                      yeah that thing was a monster!
                      I like what your talking about, but as you said earlier, the turbo is going to act as a muffler also so I'm thinking a single metal core highflow cat and a muffler (where the stock one was) all with 3" tubing would be the way to go.
                      any thoughts?
                      • Boosted E30
                        • Dec 2009
                        • 288
                        Untill its turbo just do
                        Headers-> Y merge > cat or resonater > Y > stromung.
                        Then once you have the turbo on there all you need is downpipe to cat or resonater.
                        Im going to do somthing similar
                        Downpipe > 18" resonater > Y merge > dinan catback from e36 m3
                        I really dispise how bmw's look with a single outlet muffler and welding on tips is not my cup of tea either. And so what ill loose a bit of flow but im not going for world record hp either.
                        • johndoe777
                          • 5
                          i wouldn't worry about the emissions tests that's what Moses Lake is for. You only need one more test before you are exempt ... i have also taken my license plates and put them on my other stock car and that worked same year/model but different color
                          • SwiftE30
                            • Jun 2010
                            • 998
                            oh is that right johnny? for some reason I skipped over the fact that my car will be turbo and wont be able to pass emissions. But i gues thats why i have my aunts house in Enumclaw!
                            when are you getting your bigger turbo?
                            • johndoe777
                              • 5
                              turbo/intercooler upgrade hopefully this spring/summer
