Need welding advice
  • MaxBell
    • 1391
    Need welding advice
    Hey guys;
    I'm just finishing up my E30 M50 build and I'm trying to put together an exhaust.
    My only issue is that I have an exhaust hole that I can't seem to fill.
    The hole is between my two 1.75" pipes, right before the xpipe.
    I CAN'T GET THE WELD/WELDER INTO THAT AREA since the two pipes are so close together. What can I do? How do you normally weld a pipe together in dual exhaust setups?
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Tack, then drop the system and weld. Then re-install.
    • MaxBell
      • 1391
      I have it out, it's just that I can't get the welder into that very tight area between the two pipes.
      So I'm wondering how all the other dual pipe guys do their exhaust welding?
      • bmwstudent
        • Sep 2011
        • 1364
        pics?
        • MaxBell
          • 1391
          The problem is that the two pipes are close together and so there are two little holes on either side of the inside of the area.
          • bmwstudent
            • Sep 2011
            • 1364
            i don't know man thats a tough one. if you can't get the mig gun in there you could try stick welding it. If you can't do that, try clamping it with a flat band clamp.
            • 619E30
              • 1753
              Tig
              Originally posted by audiquattrot
              bimmers b4 b*tches....remember that.
              1990 Alpinweiss 325i - secret 500whp build
              2000 Audi S4 B5 Laser Red
              1990 Nissan 240sx - Drift Missile
              2006 CBR600RR
              • e30shmobberr
                • 1934
                What type of welding?
                Patrick - IG:niicknac
                RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
                • MaxBell
                  • 1391
                  MIG right now, but I don't know that I have the shit for other types of welding.
                  • MaxBell
                    • 1391
                    Any other tips?
                    • ak-
                      • 12422
                      I think I've solved it man
                      1991 325iS turbo
                      • e30e
                        • Dec 2004
                        • 2176
                        Weld a plate over it and then prime it so it doesnt rust.
                        1985 BMW 325e
                        1997 BMW M3/4/5
                        2007 Chevy Silverado Crew Cab 5.3 v8
                        • jaywood
                          • Jul 2010
                          • 4528
                          Sheet of steel
                          Bend into a C shape
                          Wrap around pipe. Cover the hole.
                          Weld.
                          • MaxBell
                            • 1391
                            Wow, that's brilliant. Done.
                            /thread
