Thee inch to big?
  • Zaro
    • Apr 2012
    • 4
    Thee inch to big?
    Hey there, I was given a 3 inch stainless magnaflow muffler and I am wondering if three inch with one muffler is to big... Lack of back pressure? Before I build the exhaust Ill be buying headers, and I do have full intention on a built all motor m20... Noise is NOT an issue either.
    Thoughts and opinions please!
    Thanks.
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    some people would say so, depends on your intent though
    • ttrousdell
      • Nov 2009
      • 1770
      single 3" is usually for 300-350hp.
      The Build:
      • quickervicar
        • 1197
        I've got it (3" w/ resonator into Magnaflow). Definitely killed some midrange. Also drones like a bugger. I was planning on boost, so that was why I went so big. If you're not going to turbocharge it, I'd stick with a smaller diameter dual system.
          • 37833
          Unless you're boosting your engine a single 2.5" system is plenty.
          Grover Beach, California
          BimmerHeads.com
          • fronton
            • Oct 2009
            • 1262
            if you go with a 3" center section, be sure to get a oval section for the rear axel portion. I didn't and its the lowest part of my car which scrapes on many things. I will be redoing it to get nearly an inch of clearance back.
              • 37833
              Or if you go 3" make sure your exhaust guy does a good job. Mine never scrapes.
              BimmerHeads.com
                • 34844
                not too big if you have good headers and merges.
                it only drones if you don't have enough muffling.. or use a magnaflow :p
                FWIW, I don't have an oval pipe under the subframe, and it doesn't scrape or really hang low at all. I wasn't happy about *everything* the guy did, but he did a really good job keeping it tight to the car.
                • quickervicar
                  • 1197
                  What are you using for muffling?
                    • 34844
                    I have a 3" cat, a borla ProXS, and a dynomax turbo-something or other..
