Exhaust manifold studs: How tight?
  • e30jake
    • Feb 2012
    • 855
    So I finally got some inspiration to work on putting another m42 in my 318is. Bought it with a blown engine and it has just been sitting since then. I'm planning on putting the exhaust manifold back on tomorrow. I have brand new studs for it and tightened them finger tight, which was different for each hole. I was in a hurry and didn't think about cleaning the holes out which could have been a factor. So how tight are they supposed to be? Are the threads in the head short enough it should just bottom out by finger tightening or what?
    What it feels like owning an e30:
    88 325 S50 swap in progress
    90 325ix
  • e30jake
    • Feb 2012
    • 855
    Anybody?
    90 325ix
      • 34844
      hand tight is fine.
      • cormier
        • 380
        Clean the holes, use loc-tite, and use two nuts against each other to tighten the studs
        Not sure the spec, but I would say just over hand tight (maybe 30 ft lbs) should be fine with loc tite
        • e30jake
          • Feb 2012
          • 855
          Thanks!
          90 325ix
            • 34844
            I'm pretty sure you don't want to loctite exhaust manifold studs in place.
            • cormier
              • 380
              I've always heard to use it.. I'm sure it would be fine without as well
              Some info on this thread if you wanted to do some reading
              A simple google search produced many many results about exhaust studs, BMW or otherwise
