Single in/dual in mufflers.
  • grahamsy2k
    • 400
    I'm looking for people's opinion on whether dual in dual out mufflers preform better than single in dual out. Dual in dual out mufflers are hard to find.
    I have a m20 and I'm just looking for a little different exhaust sound.
    All just means to an end.
  • Liquidity
    • May 2014
    • 395
    Need more info. If the inlets and outlets are all the same size, then it should be obvious that a dual/dual will flow more.
    • grahamsy2k
      • 400
      What is the size of factory muffler in a 325is m20, 2.5 in or 2.25 in?
      My question isnt so much whether it will flow more because I understand that. It's whether the greater flow will noticeably change engine performance.
      • G-Man the Visionary
        • Apr 2013
        • 543
        dual 1.75"?
        Streetable poly mounts, trans mounts are here!
        http://www.r3vlimited.com/board/show...ght=streetable
        '94 318i
        '07 335i
        '11 X5
        '89 325ic m30b35
        • Liquidity
          • May 2014
          • 395
          Inch? You think Germany uses English measuring standards?
          • grahamsy2k
            • 400
            Thanks for your input...
              • Apr 2013
              • 543
              Hahaha... I got the Borla dual in/ out pro xs for use with my m30. Like the sound, just too loud for me. Can't comment on performance gains since it's a swap. What part of Indiana are you from? I'm originally from Mishawaka/ South Bend.
              '94 318i
              '07 335i
              '11 X5
              '89 325ic m30b35
              • grahamsy2k
                • 400
                Im in Terre haute. Hour southwest of Indy basically.
                did some research and most people are saying that its 1.75''
                • Madhatter
                  • Oct 2004
                  • 966
                  44mm. So, yes, 1.75"
                  Just a little project im working on
                  - http://www.lse30.com -
                  • digger
                    • Nov 2005
                    • 6122
                    dual 1.75" is same as about a single 2.5". as for mufflers it depends if it is a straight through type or something kind that might be more restrictive so the construction difference is important. chances are single 2.5" is plenty for what you need. i do like the sound of a dual system though
