AC Schnitzer exhaust from e36 m3 on a s50 swapped e30?
  • bad_azz_bmr
    • Sep 2004
    • 433
    Hi there i was wondering if anyone has tried installing an e36 m3 Schnitzer Cat-Back onto an e30?
    only reason i am asking this question is because of the angle of the outlet, it looks like it is angled about 5 degrees towards the middle of the car, does the actual muffler sit on a slight angle so the outlet is completely flat with the rear of the car?
    that is what the exhaust looks like
    thanks for any help..
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Take it to a muffler shop and have the pie cut a section, then weld it back together to get yer angle right.
    • bad_azz_bmr
      • Sep 2004
      • 433
      so get the actual tip cut off and re-welded? won't that mess up the chrome finish, or angle the muffler and get the pipes redone?
      • bad_azz_bmr
        • Sep 2004
        • 433
        i just put it under the car and it looks like the tip and the muffler will work i just have to get rid of the kinked pipes right after the muffler...
        • jahnaboi
          • Oct 2006
          • 1742
          Any update on this? Pictures?
          SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
          • bad_azz_bmr
            • Sep 2004
            • 433
            /\ no updates yet, but it looks like it will fit, a few mods to the piping and it should be ok (i should be able to get it to sit completely flush with the bumper - when looking from above)...
            s50's getting freshened up as we speak, and i am missing a few components for my swap still (driveshaft and 944 booster)...
            • jahnaboi
              • Oct 2006
              • 1742
              e21 boosters are easy to deal with or mk1 boosters.
              • bad_azz_bmr
                • Sep 2004
                • 433
                but with the e21 booster you have to reduce the diameter of the shaft and then re-thread, the 944 is supposedly the right diameter already and only have to cut and re-thread
                • jahnaboi
                  • Oct 2006
                  • 1742
                  If you have access to a tig welder, you could easily cut the threaded portion with some slack and cut the e21 booster shaft and easily weld to length. =P
                  • daniel
                    • 6703
                    right now i have a remus e36 m3 exhaust on my s52, and it kind of fits, but doesnt really. it needs to be bent in a few places to get the fitment right.
                    i am talking the whole thing, by the way, not just the muffler.
                    http://instagram.com/dslovn.drives
