glowing red manifold
  • shiboujin
    • Feb 2006
    • 2791
    I have an M50B25 NV with an HX35 with a modified ebay mani. I'm also running COP MS1 V3.
    I ran my car for a bit with the turbo loosely connected to the charge piping and it idled around 1000. After I hooked it up, the car started to idle around 2500. Then I noticed my exhaust mani was RED! I have a small exhaust leak so my O2 sensor is reading all over the place (could be noise too). I revved it a few times and it actually made 8psi at 7100rpms. That doesn't sound right at all.
    Theories? Ideas? It's kinda scary to have your mani turn red at 2k rpms just sitting still.
  • BimmerScreamer
    • Dec 2008
    • 413
    do you have an air/fuel gauge? and yes that is not supposed to happen. My guess is the ecu wasnt seeing as much air as it wanted so it pulled back fuel, than you connected the charge pipe giving alot more air now it all out of wack. Thats really just an idea, I am not a MS expert, what are you running for air metering?
    Anything can be done
    • shiboujin
      • Feb 2006
      • 2791
      Theres a leak in my exhaust so its off. The signal in my datalog is WAY shakey. I don't know if its because of the leak or because of bad wiring.
      • dot communist
        • Jan 2009
        • 24
        attachment relevant :D
        • decay
          • 5637
          well dude, if you have 2 potential problems and are not sure which is causing the lean condition, the logical thing to do would be fix one of them and see if it goes away...
          i would start with the exhaust leak, esp if it's before the O2 sensor.
          i thought you had a shop finishing this build now?
          past:
          1989 325is (learner shitbox)
          1986 325e (turbo dorito)
          1991 318ic (5-lug ITB)
          1985 323i baur
          current:
          • LowR3V'in
            • 4209
            What's advance are you seeing at idle?
            You sure the antilag isn't on?
            • shiboujin
              • Feb 2006
              • 2791
              Leaks are fixed but the heat killed my spark wiring.
              The shop flaked on me. Kept the car for 4 months and didn't do shit. So I took it back and am finishing it. 4 months wasted...
              It was idling at 2500rpms and about 19 degrees of advance.
              • evil_twin
                • Nov 2007
                • 2965
                You might be running a bit rich with a misfire. My maxima did that when it was missing bad. I think you're dumping too much fuel.
                Paypal: vdang5@gmail.com
                Delta Auto Care
                2875-C Towerview Road
                Herndon, VA
                703.435.1375
                My Feedback Thread: Evil_Twin
                • shiboujin
                  • Feb 2006
                  • 2791
                  eh could be. I redid the spark wiring and now it idles lower. still at about 1700 tho. I wonder why...
                  • Tchao
                    • Apr 2007
                    • 223
                    This whole build is sloppy.
                    Id make sure you are really at 19* advanced. It only glows without load when your timing is wacked beyond belief.
                    • dashboardmonkey
                      FUCK YOUR WAFFLES
                      • Jun 2008
                      • 6158
                      That's hot.
                      -Andy
                      • LowR3V'in
                        • 4209
                        do you have your ICV hooked up.
                        0 vac leaks?
                        • StreuB1
                          • Sep 2007
                          • 113
                          19deg adv at idle LMFAO. thats not right AT all
                          I like to build things with metal n stuff
                          • PiercedE30
                            • Apr 2005
                            • 4220
                            Yea, for idle it should be around 10*, maybe up to 14 depending on your setup or maybe even as low as 8.
                            My 2.9L Build!
                              • 34847
                              19 degrees is actually too retarded.. for 2500rpm. why is your idle 2500rpm again?
