M20 Turbo
  • xwill112x
    • Jan 2009
    • 4237
    Originally posted by 619E30
    Fuck, haha. So if you could turbo the stock m20, how come most people build a low-compression stroker?
    tuning is a bitch, and you have to mount a intercooler, all the plumbing for that, have to make oil lines, have to have a turbo and a mani for it...
    the stroker is easier than turboing. if it was me, id do a low comp 2.7i, then a huge turbo.
    • lifeiskaos
      • 1709
      Because people are stuck on thinking that .2L more displacement will do wonders, and that "low compression" will allow you to run moar bewst and make tons of powarr
      As you now know, you can make tons of power on a stock m20b25. 8.8:1 compression is already relatively low.
      My turbo m20 was a "2.7i" stroker. I wanted some buffer room for DIY tuning and crappy california 91 octane gas, and thought more displacement would do wonders. I wish I would have boosted my stock engine.
      Now I'm building an m52 turbo at 9.5:1 CR
      edit: oh, and lots of people who build "strokers" start out with ETA's. It's easy to swap out the head and electronics to get some more RPM's for the turbo.
      • 619E30
        • 1753
        Well it's either I turbo the m20 sitting in my garage or the m50 sitting in a salvaged e36.
        Which would be more beneficial to turbo?
        Originally posted by audiquattrot
        bimmers b4 b*tches....remember that.
        1990 Alpinweiss 325i - secret 500whp build
        2000 Audi S4 B5 Laser Red
        1990 Nissan 240sx - Drift Missile
        2006 CBR600RR
        • lifeiskaos
          • 1709
          I see. So where could I find those?
          In the thread I posted, there is a link to rent a DIY oring cutter. I think you can also buy wire from them. It's $60 to rent IIRC
          • lifeiskaos
            • 1709
            If it's a vanos m50, then I say go with that. More bolt on mods and tuning options. If it's a nonvanos, then I'd say stick with the m20. When you blow the m20, you can go 24v. That's what the cool kids do :p
            • 619E30
              • 1753
              Well it's a single vanos, and I've heard bad things about turboing those
              2006 CBR600RR
              • dashboardmonkey
                FUCK YOUR WAFFLES
                • Jun 2008
                • 6158
                http://www.e30tech.com/forum/showthread.php?t=59124
                This guy is running 20psi on stock internals with head studs and metal gasket. Had this set-up for a year now
                then why the fuck are you asking???
                -Andy
                • xwill112x
                  • Jan 2009
                  • 4237
                  what? the non vanos is the turbo friendly motor.
                  • 619E30
                    • 1753
                    That's exactly what someone told me
                    2006 CBR600RR
                    • lifeiskaos
                      • 1709
                      orly? Why is that? Less stock compression? dual valve springs? WOWzerz! The vanos m50's have more low end torque, meaning faster spool, longer rods, meaning higher revving, a lighter weight valve train, meaning less HP loss, and more tuning options.
                      I'm telling you otherwise. They're both decent for boost, but a nonvanos is pretty much a DOHC m20... you can really take advantage of the newer technology with vanos engines/ecu's.
                      • 619E30
                        • 1753
                        ^^ True. But both the m20 and m50 have to be rebuilt, so I think I'm going to go with the m20 for now :)
                        2006 CBR600RR
                        • xwill112x
                          • Jan 2009
                          • 4237
                          have fun fixing your bent valves and fubard vanos unit, and trying to tune the damn thing.
                          boost= non vanos
                          n/a= vanos
                          • lifeiskaos
                            • 1709
                            boost= non vanos
                            n/a= vanos
                            Do some research before you come start giving advice without knowing wtf you are talking about. Turbo'd vanos engines don't magically bend valves, and vanos units don't magically go bad.
                            If you can't figure out how to turn a switch on at a certain RPM/load, you should either not be boosting engines with standalone ECU's, or you should let good tuners like TRM tune the stock ecu for you.
                            Yes, nonvanos engines are more "beefy." Who the fuck cares? Since when are heavy rods better? The vanos engines are newer, better engineered engines.
                            • 619E30
                              • 1753
                              ^^ sounds pretty accurate. Lifeiskaos, how do you pass emissions with a turbo, or is your m52b30 going in like a track car?
                              2006 CBR600RR
                              • Chabs
                                • Jan 2010
                                • 538
                                I'm no M20 expert but I'd recommend getting head studs and a head gasket for sure. And also think about some forged pistons
                                Josh
                                http://www.r3vlimited.com/board/showthread.php?t=159843
