Garrett tb25 is it big Enough?
  • MonkeyMadness
    • 3251
    I got a Garrett Tb25 sitting on the shelf that I pulled out of the j-yard
    a couple of months ago..
    I pulled it off a Saab 900 fwd I also have a IHI I pulled off a furd probe
    2.2 but i know it's really small and will be mounting it on my buddys 1.6 Miata.. but thats a hole nother thread..
    I have another friend with an older gti 2.0 and was asking if the garrett could be mounted on the "street tramp" if not could he buy it?
    So I'm asking, is it big enough to boost the m20, too a "max" boost of 8psi with a rev limit of 7000rpm?
    I know everybody says run T3/T4 but that's the same guys pushing 12-15psi and thick head gaskets on freah engine builds..ugh:roll:
    Will this turbo work?
    ~I have stock everything at 164,000+miles
    ~Afm swapped for 2.7" Miller MAF III, but will order 3.5" housing for boost.
    ~173 ecu running a Miller W.A.R chip
    ~524td manifold
    Just ordered ported and polished wheel studs, and balanced and blue printed oil drain plug! Instlled 3point wiper blades
    So i got what in need! j/k...:-D
    thank
  • lifeiskaos
    • 1709
    No, get a bigger turbo.
    • blueapplesoda
      • Dec 2005
      • 1904
      he can run that turbo
      if he has a second one on cylinders 4 5 and 6
      • MonkeyMadness
        • 3251
        really damn...
        cool thanks for the info guys
        • yert315
          • 2734
          would it be sufficient for a 2.0l m10?
          • Danny
            • 14216
            Yes
            • 5KWattson
              • Apr 2009
              • 809
              turbo map your engine...or just find one
              "God created turbo lag to give V8's a chance" Taylor D.
              • MonkeyMadness
                • 3251
                OK went out a cleaned the turbo to sell, started searching part numbers turns out
                the turbo is a water cooled Garrett T3 (TB0356) with .42 A/R compressor housing, and .48 exhaust housing
                I'll be keeping this one.. I'm sure it will do just fine on my build...
                • turbo zombie
                  • Dec 2009
                  • 13
                  those trims are about what volvo used on it's turbo motors in the 80's on their 2.3L redblocks. it can make enough pressure, yes, but it's about airflow as well. i strongly doubt that it will work for you past 5k rpm. you will straight up not make extra power past that. it'll spool up quick as a bitch though :)
                  Addicted to '80s European RWD
                  1987 BMW 325e, 5 speed, torque ftw
                  Previous:
                  2005 Civic Lx Coupe, auto, sold
                  1985 Volvo 245, 5 speed (avatar), junked
                  1989 Ford Festiva, 4 speed, sold
                  1979 Volvo 242, 2.3 turbo swap, auto, junked
                  1986 Volvo 245, 5 speed, my first car, traded away, now has a turbo 5.0 w/ 5 speed
                    • 34839
                    yep, still a butt-plug.
                    • ethree
                      • Aug 2007
                      • 1213
                      I may be interested in this turbo for my 1.6 diesel. Have any pics? Standard t3 flange? What about exhaust housing?
                      • mrsleeve
                        • Mar 2005
                        • 16386
                        big exhaust restriction above 4800-5000rpm
                        Originally posted by Fusion
                        William Pitt-
                        • fiftytakedowns
                          • 2460
                          What size turbos do you recommend for an m10 motor then? I have a .42 trim, with .40 a/r
                          [/url]
                          Team USA Wrestling 67KG
                          • turbo zombie
                            • Dec 2009
                            • 13
                            that would prolly work well for a stock m10.
                            Previous:
