injectors
  • 6gen91
    • 712
    injectors
    soon to boost the b25. what size injectors should i use if im going to run loow boost? are 19lbs fine? opinions please.
  • lifeiskaos
    • 1709
    What are you using to control fuel? I wouldn't really try much more than 24 on motronic, and if you're using a standalone like megasquirt, you may as well go for something bigger, like 42 lb injectors. They're not much more expensive, and they'll give you the option for more boost.
    • Jaxx_
      • Dec 2009
      • 1880
      how much is low boost?
      power goals?
        • 34844
        19# are too small for any level of boost, anyway.
        • blueapplesoda
          • Dec 2005
          • 1904
          • 6gen91
            • 712
            I was thinking of just chipping the ecu
