Im doing an s52 swap in my 89 352i, im going to have a 3.23 LSD diff and i am at the point where i need to buy exhaust manifold and turbo. Just wanted to get a little advice and info on what setup's people are running and if you have any suggestions on what i should do. Thanks
Turbo's?
the thing that will help you the most is to first consider where you want your power, after that, learn to read compressor maps and find an appropriately sized turbo for your application. the squirrel performance calculator is great if you want to look at turbo size vs engine size/speed.'84 318i M10B18 147- Safari Beige
Originally posted by StereoInstaller1 View Postwww.blunttech.com for the manifold, or PM Good&Tight
yeah i am definitly going to be going with a Good & Tight manifold. they look awesome.
Originally posted by Jaxx_ View Postthe thing that will help you the most is to first consider where you want your power, after that, learn to read compressor maps and find an appropriately sized turbo for your application. the squirrel performance calculator is great if you want to look at turbo size vs engine size/speed.1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
just an overall solid driver that i take out on sunny days. Something with a strong power band that doesnt raapp out in first and second gear with a really strong pulling third gear. Top spead isnt that much of interest. Something around 150 tops would be nice. Im pretty sure i'll be running a 3.25 LS Diff1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
Originally posted by SwiftE30 View Postyeah i am definitly going to be going with a Good & Tight manifold. they look awesome.
I was just curios as to what setups, mainly types of turbos, people are running and how they like them. ya know, how much boost, what size wastegate. etc...
We have down pipes that will be available for purchase along with the manifolds to make install easier.Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
I recommend a gt3076 with a .82 turbine housing. Wicked turbo. On a stock s50b30us it was awesome. I am running it on my m20b25 now and its slightly oversized, but it still spools faster/better than any journal bearing snail I have tried. These are on street cars.
We just upgraded from this turbo on the s50 to a gt3582 cause we wanted to move to a t4 housing platform for moar flow and higher peak power.Last edited by blueapplesoda; 09-02-2010, 11:00 AM.
this might be a retarted statement/question but the T3 and T4 and T3/T4 are all sizes of turbo mounting right? Like how big of a turbo you can mount to your manifold?
I think am kind of leaning toward a GT35r because i dont want to be under powered/limited with a small turbo, and it seems like people are having sucees with their builds with that turbo.1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
First of all have you ever driven an NA s52 e30? It's pretty fast already.
Of course I understand the power bug completely.
Are you planning on building the bottom end for reliability as well then? How much boost do you want? I was under the impression that a GT35r was a pretty serious turbo depending on the trim and that they can bend rods and what not.
'89 Alpine S52 with goodies
No unfortunatly I have not driven an N/A e30 s52. But I have driven my brothers 97 m3 with a vortex V2 supercharger, headers, and m50 conversion and it's just not fast enough for me. And I know it's not the best comparison but I've always wanted an FI car.
But as for the turbo, I definitly need to do more research before I buy and that was the point of this thread. I've been recommended to go gt35 and others. But as of now I will not be rebuilding my bottom end. So if the gt35 is too much on stock internals i dont think that's the turbo for me.1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
At what point of boost do you think will start causing problems and damage? And I think putting some new studs would be a good thing to do when the engine pulled. Maybe some ARP studs? How hard is it to replace the cam with a pulled engine? If I'm there, I might as well to ensure a strong long lasting engine that is capable of more boost if wanted later down the road.1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
