Turbo M20 Build
Build Thread
http://www.e30tech.com/forum/showthread.php?t=84988
"When In Doubt Boost It Out"
~89 325I Turbo 11.90 @ 121~
~ 420whp/420tq~
15psi
~Paul Burke Built 2.8L Stroked M20
~666 Divided Mani T3
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates -
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 GatesComment
Beef, I think we have the same oil cooler... I was able to fit it nicely behind the kidneys. If you want a pic I'll get it for ya Friday. All I have now is this.. (I pulled em off for cooling but they fit fine.
Sent from my SCH-I545 using Tapatalk 2Comment
I had it behind the kidney's but since I run my IC up side down it sits higher and won't fit with the earl fittings. I had to run in on a diagonally and didn't like it.
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
I think Pete said it best Iv seen a lot of swedes make serious power on stock rods. I did a little extra to make my rods a little stronger but keeping those spikes controlled is key. I had slight issues with that this season because I was running a MBC.
Keeping a flat torque curve is what i'm trying to achieve with electronic boost controlling. Also not coming off the line with so much boost in first gear that I hurt internal engine components.Last edited by beefjurky69; 11-28-2013, 06:49 PM.
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
But nowhere close to being the smartest one around...
Sounds like you are heading the right way about it then beef. I ramped the boost on the m20 and it was epic! Instead of tapering away, it just got more frantic a revs increased.
And then the fuel pump died..... :(Comment
Sorry for changing the quote on you so quick wanted to add a few more things. No one knows it all but you've been around long enough that I would trust a good amount of your input.
I'm hoping to be going down the right path I do enjoy the m20 and want to be up there with the top m20 guys. Baby steps though and getting my ducks lined up is my focus to keep this motor together and not have and stupid issues. Also hoping that e85 works wonders for me.
Yea that fuel pump issue sucks and those are stupid issues I don't want to happen.
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
