Turbo M20 Build
  • beefjurky69
    • 613
    Turbo M20 Build
    Well here we go finally started my turbo build. Looking on making around 350hp/400 would be awesome. My platform is an 89 325i with 79,000 miles Florida car. Here are a few pics let me know what u guys think.
    Build Thread
    http://www.e30tech.com/forum/showthread.php?t=84988
    "When In Doubt Boost It Out"
    ~89 325I Turbo 11.90 @ 121~
    ~ 420whp/420tq~
    15psi
    ~Paul Burke Built 2.8L Stroked M20
    ~666 Divided Mani T3
    ~6262 T3 Turbo
    ~O'ringed Block SS
    ~Custom Fuel System
    ~3'' Turbo Back
    ~50mm Tial Bov
    ~Dual Tial 38 Gates
  • beefjurky69
    • 613
    Got the valve cover and intake manifold sand blasted and painted at my job
    Here's a few pics of some parts and hardware
    Few pics of the VEMS engine harness
    Heres a few pics of the fabbing I did...intercooler pipes and exhaust wrap
    The oiling system and suspension
    I'm almost done with the build here's a few pics of when I got the car and how it sits now...still have to install a clutch finish the VEMS harness and tune the thing
    Before
    After
    Enjoy thanks for looking
    Build Thread
    ~ 420whp/420tq~
    15psi
    ~6262 T3 Turbo
    ~O'ringed Block SS
    ~Custom Fuel System
    ~3'' Turbo Back
    ~50mm Tial Bov
    ~Dual Tial 38 Gates
    • akw_
      • 34
      wow nice build!
      how big is your intercooler? im realy liking the look of the cooler piping
      • Danny
        • 14216
        Interesting wastegate routing...
        • beefjurky69
          • 613
          Originally posted by akw_
          wow nice build!
          24x12x3 is the cooler size...thanks I tried to make them as short as posiable
          What's so interesting? Is it bad? Not efficiant?
          Build Thread
          ~ 420whp/420tq~
          15psi
          ~6262 T3 Turbo
          ~O'ringed Block SS
          ~Custom Fuel System
          ~3'' Turbo Back
          ~50mm Tial Bov
          ~Dual Tial 38 Gates
          • IRON-E
            • 16548
            I'm really digging the TARBO e30 influx we've had lately, I might have to start looking for an SETA engine and collecting parts like a squirrel.
            Nice build.
            @IRON-E30 aka Edwin:D
            • beefjurky69
              • 613
              Nice build.
              Thanks man can't wait till it's done...I try to do it nice and clean
              Build Thread
              ~ 420whp/420tq~
              15psi
              ~6262 T3 Turbo
              ~O'ringed Block SS
              ~Custom Fuel System
              ~3'' Turbo Back
              ~50mm Tial Bov
              ~Dual Tial 38 Gates
              • einstein57
                • Jun 2007
                • 10780
                Very clean install. Wish i had your welding skilz. As far as the wastegate the outlet should have a flex pipe to allow for thermal expansion right? Considering how long your plumbing is, its probably going to have all kinds of internal stress.
                www.gecoils.com
                • beefjurky69
                  • 613
                  i was thinking about running a flex pipe but i figured since the bmw engine are mounted on an angle and the stock exhaust systems dont use a flex that i might be able to get away from using one.
                  It could completely back fire on me and crack but im hoping by running poly engine and trans mounts i shouldn't get to much movement to crack the welds (im hoping) i guess time will determine that if it cracks than i'll put one. if i dont need one i rather not use one cause they look pretty ugly especially up top where everyone can see it
                  Thanks for the comments i been practing tig welding for over a yr just about everyday its hard when you first start but once you have a flow its just like everything else it just gets easier...i also fabricate at maximum psi for a living so being around it everyday also helps alot
                  Build Thread
                  ~ 420whp/420tq~
                  15psi
                  ~6262 T3 Turbo
                  ~O'ringed Block SS
                  ~Custom Fuel System
                  ~3'' Turbo Back
                  ~50mm Tial Bov
                  ~Dual Tial 38 Gates
                  • einstein57
                    • Jun 2007
                    • 10780
                    The factory exhaust does have a flex section in one of the down tubes. Its more about expansion then flex and considering that the wastegate only has gases flowing through it breifly it won't be nearly as hot as the rest of the down pipe. So the likely hood of a crack developing are great. Especially if you use stainless. And the longer the wastegate plumbing the more likely it is to crack.
                    www.gecoils.com
                    • azael325i
                      • Dec 2009
                      • 1258
                      OMG I like great job
                      http://www.r3vlimited.com/board/show...46#post3229446
                      • beefjurky69
                        • 613
                        yea thats tru it makes sense i guess once it cracks if it does then ill add it in then
                        Thanks man
                        Build Thread
                        ~ 420whp/420tq~
                        15psi
                        ~6262 T3 Turbo
                        ~O'ringed Block SS
                        ~Custom Fuel System
                        ~3'' Turbo Back
                        ~50mm Tial Bov
                        ~Dual Tial 38 Gates
                        • kid325e
                          • Sep 2007
                          • 6421
                          Looks good. Props on the skillz.
                          clutchCTRL!
                          Move with a purpose.
                          - 1991 325iX 4dr/5spd
                          - 2000 323i AT
                          2016 Mazda CX3 Sport AWD
                          • blueapplesoda
                            • Dec 2005
                            • 1904
                            No flex you will be fine. I don't have a flex on my wastegate tubing, internal stress can suck it.
                            Then again, I made my wastegate plumbing as short as possible to minimize thermal expansion...of course at the cost of slight turbulence of exhaust stream. After the wbo2 and the egt sensor of course..
                            Nice build, good choice on EMS.
                            • beefjurky69
                              • 613
                              Thanks guys...here are a few vids of the car running finally she's up and going. Just a few more things left and off to the rollers. Also a few updated pics of the car.
                              Build Thread
                              ~ 420whp/420tq~
                              15psi
                              ~6262 T3 Turbo
                              ~O'ringed Block SS
                              ~Custom Fuel System
                              ~3'' Turbo Back
                              ~50mm Tial Bov
                              ~Dual Tial 38 Gates
