Turbo M20 Build
  • Nutzy
    • Sep 2011
    • 102
    #286
    Originally posted by LowR3V'in
    Get ready for 8mpg ;)
    F*ck yeah, my 30 gets about 18 liters per 100kms on corn juice.
    89 M50B28 turbo
    LINKY
    • beefjurky69
      • 613
      #287
      Yea I'm prepared for that...I'm also not running e85 all the time it's a bout a good 30-40 min drive to get to the pump. Only really running it on track days and possible street runs.
      Build Thread
      http://www.e30tech.com/forum/showthread.php?t=84988
      "When In Doubt Boost It Out"
      ~89 325I Turbo 11.90 @ 121~
      ~ 420whp/420tq~
      15psi
      ~Paul Burke Built 2.8L Stroked M20
      ~666 Divided Mani T3
      ~6262 T3 Turbo
      ~O'ringed Block SS
      ~Custom Fuel System
      ~3'' Turbo Back
      ~50mm Tial Bov
      ~Dual Tial 38 Gates
      • Nutzy
        • Sep 2011
        • 102
        #288
        The closest e85 pump to me is about 5 minutes drive, but I still take a bunch of plastic of 20 liter plastic Jerrycan's to fill up as well.
        My M20 is using lots of e85, but then it would be using lots of 98RON anyway because of the almost dead state of the motor. My fuel table has 30% added to the entire map via the global multiplier.
        89 M50B28 turbo
        LINKY
        • beefjurky69
          • 613
          #289
          5 min is nice i bought a 5gal race container so i can fill that up when i go to the track. I wont mess with the maps myself just yet i need to learn it a little better dont want to mess anything up. My tuner said it wont cost much for a re tune he's also setting up my EBC so ill have everything done while im there for that session and also have ramp boost working which is what im real excited about.
          Can only have so much control with a MBC and im kinda tired at being a full boost when not needed. I do enjoy cruising around with my car and full boost isnt needed all the time.
          Build Thread
          ~ 420whp/420tq~
          15psi
          ~6262 T3 Turbo
          ~O'ringed Block SS
          ~Custom Fuel System
          ~3'' Turbo Back
          ~50mm Tial Bov
          ~Dual Tial 38 Gates
          • beefjurky69
            • 613
            #290
            1st step of cam syn is done. Waiting on coil bracket and cam plate to be cut out all designs are done just waiting for a machine to open up.
            Build Thread
            ~ 420whp/420tq~
            15psi
            ~6262 T3 Turbo
            ~O'ringed Block SS
            ~Custom Fuel System
            ~3'' Turbo Back
            ~50mm Tial Bov
            ~Dual Tial 38 Gates
            • bobross
              • Jul 2005
              • 753
              #291
              mitas whale
              -Greg
              90 325isT - 12.2 @ 120ish - Dyno Results
              b18c5 EG Coupέ - 13.5 @ 100ish - Dyno Results
              • beefjurky69
                • 613
                #292
                So I decided to re plumb my waste gates after noticing the silicone vacuum lines were melting. I thought of using Parker push locks but the plastic tunes only handle 140 degrees of heat so that was no good.
                I ended up saying fuck it and went with xrp fittings...also re located the oil cooler again, didn't like were it out it last time...here are the pics
                Build Thread
                ~ 420whp/420tq~
                15psi
                ~6262 T3 Turbo
                ~O'ringed Block SS
                ~Custom Fuel System
                ~3'' Turbo Back
                ~50mm Tial Bov
                ~Dual Tial 38 Gates
                • 10yre30r
                  • Jan 2010
                  • 97
                  #293
                  NIce work. Do i have to be tuned for e85 or could i possibly use a safe mix of it say 50/50 ...i use it with my bmw 135i ...was hoping i could do the same with the e30 turbo..?
                  • FLG
                    • Sep 2011
                    • 3165
                    #294
                    You'll need to have a tune. Stand alone does not work like the stock ecu where It can compensate itself/learn. You could have a second tune hooked up that you could switch on the fly but that's about it.
                    Sent from my SCH-I545 using Tapatalk 2
                    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                    • LowR3V'in
                      • 4209
                      #295
                      Megasquirt you can.
                      • beefjurky69
                        • 613
                        #296
                        I usually say tune anytime you change fuel because all fuel s different...play it safe no need to blow a motor because of lacking a tune.
                        In a few months ill be tuning for e85 and regular pump gas...even the fact that I canged my inj to bigger ones I would retune on just pump. My tuner is super picky which I love "same guy who tuned your car when the previous owner had it" he always wants the most perfectand efficant tune and never second guesses anything. He also never pushes it to the limit is he feels its not safe.
                        Build Thread
                        ~ 420whp/420tq~
                        15psi
                        ~6262 T3 Turbo
                        ~O'ringed Block SS
                        ~Custom Fuel System
                        ~3'' Turbo Back
                        ~50mm Tial Bov
                        ~Dual Tial 38 Gates
                        • Northern
                          • 5185
                          #297
                          You should watch for chaffing where those lines are laying against each other. AN lines love to chafe through each other.
                          You could prevent them from rubbing by bolting them together with adel clamps if you haven't already.
                          Originally posted by priapism
                          Originally posted by shameson
                          • beefjurky69
                            • 613
                            #298
                            So randy forbes subframe kit is on it's way.
                            Build Thread
                            ~ 420whp/420tq~
                            15psi
                            ~6262 T3 Turbo
                            ~O'ringed Block SS
                            ~Custom Fuel System
                            ~3'' Turbo Back
                            ~50mm Tial Bov
                            ~Dual Tial 38 Gates
                            • beefjurky69
                              • 613
                              #299
                              A few more updates...here are all the drawings for the cam sensor plate and ls1 coil bracket that going on top of valve cover.
                              Build Thread
                              ~ 420whp/420tq~
                              15psi
                              ~6262 T3 Turbo
                              ~O'ringed Block SS
                              ~Custom Fuel System
                              ~3'' Turbo Back
                              ~50mm Tial Bov
                              ~Dual Tial 38 Gates
                              • beefjurky69
                                • 613
                                #300
                                Started the rear diff brace build today...here's a pic of the material I'm using.
                                2x2 1x2 and 1x1 square tubing
                                After figuring out where diff height was I started cutting...started cutting by 10am and by lunch this was the progress
                                Original channel that comes from factory
                                E36 diff cover bolts right up...only is sure is the speedo ring need to be cut because it slightly hits the cover...about an 1/8 on each fine.
                                Here I just laid out some tubing to see how everything is gonna play out. Still need to trim down the rest of the oem channel left on the frame rails. Need to grind off the boddy sealer that's all over and start welding the angle iron support to the rail and get the main brace tacked in place.
                                Build Thread
                                ~ 420whp/420tq~
                                15psi
                                ~6262 T3 Turbo
                                ~O'ringed Block SS
                                ~Custom Fuel System
                                ~3'' Turbo Back
                                ~50mm Tial Bov
                                ~Dual Tial 38 Gates
