Turbo M20 Build
Build Thread
http://www.e30tech.com/forum/showthread.php?t=84988
"When In Doubt Boost It Out"
~89 325I Turbo 11.90 @ 121~
~ 420whp/420tq~
15psi
~Paul Burke Built 2.8L Stroked M20
~666 Divided Mani T3
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
How are you going to wire your coil on plug setup? similar to wasted spark and have 2 fire at the same time?
Also, with adding the 2 vent tubes, are you still going to use the stock one or plug that? Did you put any type of baffling inside the valve cover on those are they just straight through to the catch can? I ask because i an planning out to do something similar.sigpic
Instagram @rebellionforge
Originally posted by IronFreak View PostHow are you going to wire your coil on plug setup? similar to wasted spark and have 2 fire at the same time?
so maybe different ways of building a catch can that I used a similar setup that a friend of mine came up with lets see if it works. One idea I had was to go right to the oil pan and cure the issue at the source but to that right you would need to drill a hole at the front on the oil pan above oil level. Doing it that way will push oil away from drilled hole under accel. That way the problem never gets to the cyl head.
Its pretty hard to do that set up on an m20 where the accessories are right up front in front of the oil pan so I ended up scratching that idea.
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
Originally posted by sayed ali View PostWow damn that coils bracket!
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
Originally posted by Q5Quint View PostThis reminds me of my ex girlfriend-
completely insane but I love you anyway.
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
What are the two o2 sensors for? Wideband display and tuning?sigpic
Originally posted by IronFreak View PostWhat are the two o2 sensors for? Wideband display and tuning?
Build Thread
~ 420whp/420tq~
15psi
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 Gates
