stuck on step 22 on MSII build
  • Project 325i
    • 182
    Im stuck, do i install this or what do i do?
    On Megamanual im on step number 22:
    22. Now you need to make a decision on the first 'optional' component: if you are going to use an IAC stepper motor with MegaSquirt-II, you must install a jumper from the hole marked S12C to the hole marked JS9 (+12C). These are on the bottom side of the board, on the DB9 side of the processor. DO NOT INSTALL THIS JUMPER FOR NON-MegaSquirt-II APPLICATIONS - IT WILL DESTROY THE PROCESSOR!!
    If you are going to use a stepper style IAC (such as the GM IAC), you need to connect jumpers to bring the controller signals out to the DB37:
    • Connect (1A)JS0 (under the processor socket) to IAC1A (near the DB37 connector) - this brings out IAC1A on DB37 pin #25
    • Connect (1B)JS1 (under the processor socket) to IAC1B (near the DB37 connector) - this brings out IAC1B on DB37 pin #27
    • Connect (2A)JS2 (under the processor socket) to IAC2A (near the DB37 connector) - this brings out IAC2A on DB37 pin #29
    • Connect (2B)JS3 (under the processor socket) to IAC2B (near the DB37 connector) - this brings out IAC2B on DB37 pin #31
    If you will be using an ignition output signal to control a coil or ignition module with MS-II, you will, likely be directed to jumper JS10 to:
    • IGN, or
    • IGBTIN, with IGBTOUT jumpered to IGN
    If you will be using CAN communication between boards (MS-II and GPIO, for example), you should also jumper JS6 to SPR1/CANH and JS8 to SPR2/CANL
    I figured id post on here too. thanks
    Calypsorot 2.7L Stroker Turbo - Sold
    2003 Honda Civic- daily
    1997 Eagle Talon TSI - 4g63 awd turbo! PROJECT!
    • 34844
    I don't know how far you are but I'd use these instructions rather than the megamanual:
    put in the S12c jumper (you don't *need* it but it doesn't hurt) and use "IGBTIN, with IGBTOUT jumpered to IGN" for the V3.0 coil driver at Q16. I don't think you'd use JS10 for that, but rather one of the LED outputs. follow what the MSextra manual says in any case.
    • Doughnut
      • Oct 2007
      • 869
      This link is set out in amazing detail! Very nice.
      ///Monstrosity. (OO≡≡[][]≡≡OO)
      Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
