Emfitty turbo question
    Got a question for the turbo 24valvers, Im aiming for somewhere in the neighborhood of 300-350rwhp with ARP headstuds an mls headgasket and a holset hx35 on my m50, and was wondering what gasket thickness i should run? I want to have some useable amount of low end power because i hate turbo cars that wont move until 2000rpm's, and the amount of boost i run isnt an issue as long as i pull somewhere around those numbers. I was thinking of using the .120 gasket, does anybody have any helpful input?
    Thanks,
    Jesse
    86 Zinno es
    M50 inside
    Should be able to hit those #'s no problem with a stock gasket. Just need to have your tune right.
    www.gecoils.com
      Smaller turbo = quicker spool but will sacrifice top end power.
      Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
      ____________________________
      E-mail Panayiotisx2@gmail.com
      Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
        How much boost will these hold at stock compression? Cuz if i could make those numbers at stock comp and just run an hx30 for quicker spool it'd be great. Would 10-12psi get me there?
        And the tune wont be a problem, im going to run it on MS and i have access to a dyno i can use for free and a crazy swedish mechanic that likes making things with turbos go faster than they should
        86 Zinno es
        M50 inside
          Check out the e30tech forced induction stickys. Lots of info on what setups make how much power. FWIW a bone stock m20 makes 300whp+ at 14 psi.
          www.gecoils.com
            Sick, ill check those out thanks much
            86 Zinno es
            M50 inside
              Stock HG and headbolts good for 8-9psi.
              MLS w/arp's 15+psi.
              Your tune has to be spot on.
                MLS w/arp's 15+psi.
                Well then 12 psi with a good tune mls and new studs sounds like fun
                86 Zinno es
                M50 inside
