link for a good m20 turbo build
  • richardkeith97
    • 1693
    looking for something to read. nothing crazy but someone getting 300hp out of a turbo m20 that didn't spend more then a couple grand. simple is what i'm looking for. using a turbo chip.
  • LowR3V'in
    • 4209
    300hp using chips and a fpr is pretty extreme and unreliable.
    It'll be like 100psi fuel pressure and you'll need 30lb injectors.
    go to e30tech and read the turbo section for old budget projects.
    Here's a good budget build.
    • DÌEGØ
      • 690
      there are quite a bit more turbo builds over on e30tech.
      you can find a lot of good info under general turbo tech
      edit: what he said ^^ lol
      I wouldnt say its "extreme & unreliable" though, you can probably get pretty close to 300chp running 10-12psi on a fairly good setup BUT its probably not gonna be under 2 grand. yes its not the most efficient setup, you'll have to go MS to get the most out of boost but it works for people with low resources weather its tunning etc...
      Driving:1990 325iS, 2007 335i :devil:
      past BMWs: 1987 325iS turbo, 1989 325i, 1995 525i, 2000 328CI, 2001 540i, 2008 135i
      • richardkeith97
        • 1693
        thanks. i guess 250hp is more reasonable.
        • einstein57
          • Jun 2007
          • 10780
          The guy I bought my chip ,begi, and 30lb injectors off of made 297whp @ 15psi.
          www.gecoils.com
          • DÌEGØ
            • 690
            wow 15psi on motronic! what chip was it? and how was his head setup [gasket/fasteners wise]?
            pretty impressive, :up: to that guy.
            • einstein57
              • Jun 2007
              • 10780
              It was a tcd stage 2 kit
              www.gecoils.com
              • 20gmr
                • 404
                Headgasket / head bolts should not be a concern based on how much boost you are running but more of a concern based on power and tq. Your rubber valve stems hold more than 30 psi
                Dave @ Bimmerbuddies
                Contact Bimmerbuddies for all your Parts and service needs
                M20,24V,5spdSwap,Weld,Fab,Tow,Buy/Sell/Trade
                Bimmerbuddies LLC
                717-388-1256
                2971a Roundtop Rd, Middletown PA 17057
                *Ask about discounts for R3V members*
                • einstein57
                  • Jun 2007
                  • 10780
                  You do realize the pressure inside a NA combustion chamber is way higher then 30 psi right?
                  www.gecoils.com
