yes. begi is a riseing rate. check e30tech classifieds
(turboed) loss of power
www.gecoils.com
So I backed out the set screw for the fmu so it reads 0psi, disconnect the vac hose and see15psi of what I'm guessing is added fuel pressure while at atmospheric pressure. So it does help add fuel pressure. Tightened the afm up a lot and drove...found afrs at 12 approaching 0psi vac....but car completele shakes like crazy at 2500rpm in 3rd still. (Solved my loose axlenut too btw) tried messing with the afm a lil and found same scenario, running it rich still doesn't help at all. I got back from my drive and touched my ign coil, found it warm but not hot just by holding on to it. Starting to lean more towards ignition issues. All ign parts are brand new except coil.
Try 24ib. injectors. 30s might be a little too much fuel.1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
Visit www.BimmerHeads.com for all of your 12 valve needs!
