anyone running the stock AiResearch turbo from a 524td? I would like some input and details of your build. some pictures would be great. thanks.
524td AiResearch turbo
I'll be doing one in april useing a volvo garret. Basically the same turbo. Also check out the grass roots motorsports "warbird" build. It uses the garrett and a notched 524td manifold.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
I'm also using this same setup for my first e30 turbo build. I have two of these turbos now. One has alittle shaft play and need a tune up. The other one has a badly cracked hot side housing and wasted bearings.. so it more for parts.. My third one is in the mail. I picked it up from Aptyp in trade for my adaptor kit..
Hey Einstein57 Don't you still need kit? ;-)Last edited by MonkeyMadness; 02-14-2011, 11:23 AM.https://www.forabodiesonly.com/mopar...re-irs.356333/
No. Your going to make me an OBX style manifold adapter instead.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
Originally posted by einstein57 View Postno. Your going to make me an obx style manifold adapter instead.https://www.forabodiesonly.com/mopar...re-irs.356333/
I have a nice manifold adapter but its for internal wastegate and I modified my turbo to be external. Its already ceramic coated so i'd hate to weld a wastegate flane on to it. I remember seeing you had already cut some downpipe flanges and a t3 flange.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
Originally posted by einstein57 View PostI have a nice manifold adapter but its for internal wastegate and I modified my turbo to be external. Its already ceramic coated so i'd hate to weld a wastegate flane on to it. I remember seeing you had already cut some downpipe flanges and a t3 flange.
Send it and the stlye 5 intake thingy and nobody will get hurt..https://www.forabodiesonly.com/mopar...re-irs.356333/
A/R .42 cold / .48 hot, Oil only lube and cooling. TB0630 Airsearch (Garrett)https://www.forabodiesonly.com/mopar...re-irs.356333/
Originally posted by eta1987 View Postanyone running the stock AiResearch turbo from a 524td? I would like some input and details of your build. some pictures would be great. thanks.
it's also positively *ancient* as far as turbo tech goes. For the budget concious, buy a used Holset HX35, go to a diesel repair shop and get a rebuild kit ($40?). Maybe one of those ebay adapter manifolds - cheap, proven and effective. But at least the turbo wasn't based off 30 year old technology..
