need some help
  • dmjensen
    • Jan 2011
    • 804
    need some help
    so this is probably an easy answer for some of you guys but, if im going to do a turbo set up on my m20 will i need to convert the stock air flow meter or is there a way i can use it without changing that.
    so far my plan is a war chip, 25-30lb injectors, with a borg warner gm5 turbo. but idk what i need to do with the afm
    any suggestions?
  • dmjensen
    • Jan 2011
    • 804
    not to look like a total dumbass but i found this http://s1.promotionsupplies.com/ebay...-AI-SET-14.jpg
    would something like that work? because i have the capability to fab it up myself, just a matter of will that work? i've also heard of people putting the afm in front of the turbo?
    • MonkeyMadness
      • 3251
      you can buy just the war chip from miller with out the maf and they have tunes for
      turbo w/war chip on afm...
      so you don't have to do anything with it..
      • dmjensen
        • Jan 2011
        • 804
        alright, where should i set it up then?
        like infront of the turbo or just have it around the oem location
        • MonkeyMadness
          • 3251
          oem..
          if your going maf infront of the turbo...
          afm easiest setup would be oem..
          • dmjensen
            • Jan 2011
            • 804
            alright, I'm just starting to collect parts.
            appreciate the help though
            • MonkeyMadness
              • 3251
              Dude...
              these should help
              oh check out E30tech.com it's a turbo heavy forum..
              good luck and do a build thread...!
              • LowR3V'in
                • 4209
                Also shop for a clutch.
                The stock one will spin at 5psi and up.
                • dmjensen
                  • Jan 2011
                  • 804
                  would i need a clutch even if mine has been recently replaced?
                  • einstein57
                    • Jun 2007
                    • 10780
                    www.gecoils.com
                    • The Humjet
                      • Jun 2010
                      • 528
                      when you break it replace it
                      • dmjensen
                        • Jan 2011
                        • 804
                        ^ lol
                        yeah that sounds like a good idea.
                        all i need to now do is sell my other project and start buying the remaining parts
                        • LowR3V'in
                          • 4209
                          but for real though.
                          You'll turn the clutch into cream cheese if you don't keep it under 5psi. :)
                          • dmjensen
                            • Jan 2011
                            • 804
                            anyone wana explain an external wastegate if i mock up an adapter from stock manifold to turbo?
                            like how would i have to set it up and what size wastegate?
                            i apologize, I'm quite new at this..
                            • The Humjet
                              • Jun 2010
                              • 528
                              An external wastegate is a flange put before the turbo flange. So what would happen is the exhaust gasses will go through it first and the valve is always pushed closed when building boost. And at the top of the wastegate there is a nipple that is fed presurised air from the outlet of the turbo and it will push the spring down once it's hit full boost and then a valve will open and divert exhaust gasses into the dump pipe instead of the turbo. Hope I explained correctly
                              This how I learnt about wastegates, infact I have this dvd on my bookshelft
