need some help
  • dmjensen
    • Jan 2011
    • 805
    verry helpful right there^
    so basically what i need to figure out is what size to use.
    • The Humjet
      • Jun 2010
      • 528
      For your needs a 38mm will do the job. But it wouldn't matter if you go bigger. It's when your pushing serious horsepower that going for a larger external gate is crucial.
      • dmjensen
        • Jan 2011
        • 805
        okay so far I've got waste gate, inter cooler, turbo, exhaust, injectors and tune down.
        now someone told me i need a fuelpres regulator and a fmu? and now I'm lost again..
        • Hey_You
          • Nov 2009
          • 963
          You shouldn't really need to mess with your FPR (fuel pressure regulator) and if you go with Miller for the tune, you don't the the FMU (fuel management unit) which is a raising rate Fuel Pressure Regulator
          85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
          • dmjensen
            • Jan 2011
            • 805
            so i don't need any sort of fuel management, the miller chip will be able to control that?
            and does anyone have a picture or a diagram of where all the vacuum lines and the oil feed/return lines go?
            • einstein57
              • Jun 2007
              • 10780
              seriously dude? your not useing the search button or the links monkey posted.
              www.gecoils.com
              • dmjensen
                • Jan 2011
                • 805
                i have been reading all of them, i just haven't seen anything about the oil feed/return.
                I'll find something
                • MonkeyMadness
                  • 3251
                  I'll find something
                  Two spots to tap into for oil feed, Oil presure senser. Right side of the motor in front of the motor mount.
                  Next spot would be drill and tap the oil filter housing bolt.
                  Drain back:
                  Hard: Pull pan and have pung welded on.
                  Simple and low buget: buy 3/4"x14 pipe tape, then (homedepot) get a 5/8"barb x 1/2" mip fitting.
                  Drill hole, run the tap, thread fitting and jb weld last threads...Done
                  • dmjensen
                    • Jan 2011
                    • 805
                    thank you
                    I'm getting all my maintenance work done right now, replaced the timing belt, water pump, cap and rotor, fan clutch, and took out all the A/C components
                    should i be getting colder plugs?
                    • The Humjet
                      • Jun 2010
                      • 528
                      It's a good idea to change to colder plugs but instead writing an essay on spark plugs I can link you one that someone already wrote, and he also talks about every single thing about how to turbocharge your m20. This will guide you heaps;
                      • dmjensen
                        • Jan 2011
                        • 805
                        thanks for getting me started guys!
