My Turbo M20
  • PJ
    • Jul 2005
    • 71
    Originally posted by NitroRustlerDriver
    Looking amazing. That thing is going to be FAST.
    Might be a dumb question, but what is VEMS?
    I hope it will be fast, that's the point with this Project.
    VEMS is a Engine Management System :)
    "The turbo from a truck is not built for much horsepower on a gasoline engine."
    • PJ
      • Jul 2005
      • 71
      The HX50 is here, and me and Nicke started to build the WG pipes and outlet.
      Trust me, never again pulsplitt in a E30, totaly suckage.
      I also need to modifiy my compressor housing on the turbo, and making the oilreturn is gonna be alot of work.
      Testing the new snail.
      This is a solution if you are running 1x BIG ASS WG, on pulsplitt ;)
      The location of the WG is ok.
      Outlet from WG.
      • jon volk
        • Dec 2004
        • 524
        Originally posted by PJ
        NICE, i like that alot. I feel bad for the car next to ya :D
        '92 MTech cabrio: Tesla P85 powered
        IG: telsa_bimmer
        '95 Alpine M3 5.3 LS, Precision 7675, TH400/Gear Vendors OD
        10.4@136 pump gas at 3530lbs. (SOLD)
        • PJ
          • Jul 2005
          • 71
          http://www.sehlstedt.nu/peppe/media/323TIC/167.jpg
          Thanx dude, we are gonna fix the outlet today, it's just hagnin there as you can se on the picture.
          Cars to right will prolly get mad at me ;)
          • Axxe
            • Aug 2004
            • 3355
            Badass.
            Someone has an obsession for orange :D
            Keep it slideways!!
            • PJ
              • Jul 2005
              • 71
              Originally posted by Axxe
              Badass.
              Hehe, new color this winter. I'm not guilty for painting the car orange :D
              • E30godz
                • 1524
                i hope your going to put some protective something around the hole where the WG is exhausting. I can imagnie the heat peeling the paint and lots of other unkind things.
                a ring of stainless steel around it would be hot!
                Also, you may want to give that pipe some more room to move around as the engine will probably be flexing a good bit under boost!
                but perhaps you've thought of these things
                GL! and sweet car!
                • PJ
                  • Jul 2005
                  • 71
                  GL! and sweet car!
                  Hello and thanx mate.
                  Yes, an aluminium plate is manufactured as protection.
                  The engine is mounted stiff, and it's more room for the hole now, since that was just test mounting :)
                  This is what happend today :D
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    This may have been answered already, but what are the little orange fittings in the top of you intake manifold?
                    • Digitalwave
                      is a poseur
                      • 6293
                      I hope its DIRECT PORT NITROUS INJECTON!!!!
                      RISING EDGE
                      • screamingbmwe30
                        • Jan 2005
                        • 415
                        map readidngs for each runner. look at Ticco's car, he did the same
                        • PJ
                          • Jul 2005
                          • 71
                          It's fittings for: MAP, BOV, BTR, WG e.t.c.
                          • PJ
                            • Jul 2005
                            • 71
                            It won't be needed, have enough turbo to blow this in pieces a few times ;)
                            • PJ
                              • Jul 2005
                              • 71
                              It's not map readings for each runner, only one fitting is for map.
                              I don't se why you sould map read each runner :)
                              • screamingbmwe30
                                • Jan 2005
                                • 415
                                just a guess. i have seen n/a car with itbs that used a map at each runner to fine tune. although these are very exspensive engines. just a guess?
