Who's had success with a 2.5" exhaust turbo m20
  • jaywood
    • Jul 2010
    • 4528
    The downpipe that came with my turbo is a 2.5". Would I be fine running a single 2.5" exhaust? I don't really want to make a new 3" downpipe.
    I've read of people pushing 400+ hp on a single 2.5"
    Opinions?
  • Mike The Bavarian
    • 488
    you can run it. a 3" is much more efficent for a turbo though.
    • FrozenSolid
      • 276
      you can have a 2.5 coming out of the turbo and make the rest 3", my old turbo had a 2.5 or a 2.25 outlet iirc, but 3" exhaust.
      • Mike The Bavarian
        • 488
        it'd be better to have a 3"dp and then a 2.5 exhaust.
        • FrozenSolid
          • 276
          my comments where towards the downpipe.. as in cutoff the flange that bolts to the turbo and make the rest of the downpipe 3". an inch of 2.5 before it hits 3 wont make a difference. of course this depends on what the outlet size of the turbo is, and if hes worried about retaining the whole downpipe or just the flange section.
          • Dj Buttchug
            • Jun 2010
            • 7672
            just run 2.5 itll be fine
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • Kvasi
              • Apr 2011
              • 1122
              2.5" will do up to around 400hp.
              • jaywood
                • Jul 2010
                • 4528
                I'm going 2.5"
                It'll make everything easier, and I'll have more ground clearance ;)
                • Tchao
                  • Apr 2007
                  • 223
                  How is it easier?
                  You are building an exhaust....I just dont get why people do shit the wrong way, or even ask for second opinions on the wrong crowd just to get an answer they wanted to hear.
                  FYI the downpipe is the easiest part of the exhaust.
                  The OP should of asked: Hi Im making an exhaust from scratch for my turbo M20. Should I do or 2.50 or 3.00? My ghetto kit came with 2.50 down pipe.
                  • jaywood
                    • Jul 2010
                    • 4528
                    Originally posted by Tchao
                    How is it easier?
                    It's easier because I have the downpipe already made.
                    Correct ;)
                    • jaywood
                      • Jul 2010
                      • 4528
                      Maybe this will help people:
                      I'll be running ~10 lbs of boost on a t3 turbo. I'm looking for roughly 250 hp.
                      This isn't an all out performance car. It's my dd.
                      I know 2.5" will work. My question is, how well will it work? What performance gains am I losing (if any) from not going 3"?
                      • Toadleg
                        • May 2011
                        • 209
                        electric cut outs are nice if your concerned about clearance. 3 inch down pipe cut out than 2.5 out the back or smaller..... my two cents
                        • Kvasi
                          • Apr 2011
                          • 1122
                          You wont loose anything. Theres no reason for the downpipe to be bigger than the outlet on the turbo. Exhaust cool down on its way out and takes less room so you really dont need a big pipe at your numbers.
                          • jaywood
                            • Jul 2010
                            • 4528
                            That's all I needed to hear.
                            I like explanations.
                            Thank you
                            • Tchao
                              • Apr 2007
                              • 223
                              Thats absolutely incorrect.
                              Like others have said, you rather 3" DP and 2.50 the rest.
