turbo the e30, now cut out when shifting?
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    What regulator did you get?
    • euro2fast4u
      • 545
      this should be great, nice progress!!! any photos how do your plugs look
      • custom e30
        • Nov 2009
        • 347
        each set only has 5 injectors but both sets are 30lbs, both sets came out of volvo 850 turbo's which are very common in my area, but it sucks cuz there all 5 cylinder engines im gonna use all the red ones and 1 of the orange, thank god they all have the same rating, lol...also i have a extra fuel rail and a extra intake, so once the fpr come in this week i will have the intake sand blasted, pained, add the in injectors and the fpr to the fuel rail, install on the intake and install on car all at once, should be pretty simple, o and here is the link to the fpr i bought
        • Hey_You
          • Nov 2009
          • 963
          RRFPR stands for Raising Rate Fuel Pressure Regulator. It increases fuel pressure when it notices boost. That's what you want, not just a standard FPR. With the 30lb'ers you should be okay under boost, but you will be dumping way too much fuel at idle/non boost situations.
          85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
          • custom e30
            • Nov 2009
            • 347
            well this is adjustable so i should be able to adjust it to be stoich at ide and when i start boosting it should be opening up, thats what i read, i can be wrong, someone correct me if this sounds wrong?
            but here is wat i found.
            • custom e30
              • Nov 2009
              • 347
              and i also read on this forum somewhere that rrfpr are a bad idea for a turbo set up, i cant remember why it would be bad so im not gonna get into that cuz then ide be making shit up,
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                Wrong.
                Rising rate is not the same as adjustable.
                Since you like to shop at eBay, here is a link for you. I told you when this all started what type you needed, but you didn't listen.
                • custom e30
                  • Nov 2009
                  • 347
                  I know that rising rate is not the same, but i have done alot of reading and from what i have read for my set up, this is better for me, i do appriciate ur input though, i will keep it in my if i have any issues, thanks again
                  • custom e30
                    • Nov 2009
                    • 347
                    Off the topic, i have nother question, i have a tre 340 fuel pump, it is 255lph, what is the psi on this pump? Ive been reading and im getting different anwser's,
                    and does anyone know the psi of the oem bosch pump?
                    • euro2fast4u
                      • 545
                      btw those injectors are both high and low impedance. but i figured you knew that
                      Originally posted by custom e30
                      http://www.e30tech.com/forum/archive/index.php/t-5552.html
                      also did you read the rest of bimmerjims post after the rrfpr?
                      Wrong.
                      http://cgi.ebay.com/ebaymotors/NEW-B...item4cf9241e4d
                      30 dollar part determines if this motor will run rich or lean. yea that will make it last
                      One thing i can agree on is you dont listen.
                      Btw keep this thread open i wanna see pictures of the motor after the first 5 times you hit boost
                      • custom e30
                        • Nov 2009
                        • 347
                        hmmm really, Ive am doing what im doing because after all the hours of searching this is what i have found is the best for me, one guys says different and everyone is giving me shit, its all good, i have tons of help from friends who have turbocharged there own cars and and much more, so i think ill be doing OK for my first set up, any help on the fuel pump info
                        • euro2fast4u
                          • 545
                          for the pump i dont know but i do know those injectors will cause you an issue. running 5 low and 1 high will either burn out the injector or the ecu. and since your running a stock ecu i would go with low since thats what came stock and just find one more. Im running a walboro not a bosch so i cant give you that value sorry.
                          • The Humjet
                            • Jun 2010
                            • 528
                            After reading that thread you posted I think that adjustable FPR you got is supposed to work in conjunction with an ems like megasquirt just to bring the fuel preasures up when that bit more is needed. They won't raise the fuel preasure when under boost for that you'll need an fmu. IIRC someone I know on my local forum was using 12:1 fmu. But his car was a budget beater that's only goal was to run 13 seconds down the 1/4 mile for $1300. He didn't car all much about have a reliable car to drive on the strees. Only to pull a quick 13 second pass.
                            Yours isn't one of those I'm sure. You don't wanna be popping head gaskets leaving you stranded when out on a cruise.
                            Build it to be reliable get yourself a standalone like Vems or Megasquirt or if that's too hard a Miller W.A.R m20 turbo tuning package will give you everything you need for safe reliable boosting. Then get yourself some better injectors not some mixed and matched ones.
                            We're not trying to be assholes many of us have all done it and we're just trying to guide you in the right direction.
                            • euro2fast4u
                              • 545
                              To maximize the effiency of that rrfpr you will need a http://www.diyautotune.com/catalog/i...844-p-467.html
                              inorder to monitor your afr's run to lean pop goes the motor run to rich fowl plugs and loose power. you want a afr around 12.4 under boost and wot
                              • custom e30
                                • Nov 2009
                                • 347
                                is ur walboro a 255lph, if so what amount of psi are u pushing, be caus ei have a tre 340 which is a 255lph?
