wanting to boost my e30
  • reztat
    • Dec 2010
    • 72
    Noob question here, just in the motor, how much money can go for 200-250 hp to the ground on a super eta?...Same as you guys, I just want a fun car not a jet, also I dont want to convert to stroker due to much money in doing it wright...Thanks in advance, any opinion will be nice.
    • einstein57
      • Jun 2007
      • 10780
      Depends on how thrifty and how lucky you get. I could do it for $600. And no i will not put together a $600 kit for someone. Do your own damn searching. lol. But a good tip for eta builds is to use volvo turbo injectors. They are 29lb low impedance which is perfect for e electronics
      www.gecoils.com
      • FunfGan
        • Jan 2011
        • 4958
        Originally posted by The Humjet
        A Mitsubishi Evo 16g would do the trick, also garret t28 would be good. You can nick one of a Silvia240sx whatever you Americans call it.
        And good'n'tight makes very good manifolds he should be able to do an m42 manifold since he usually sells m50 manifolds, he could take off a couple cylinders on cylinder 5 and 6 and it should work the same. You might wanna get an MLS and arp head studs as well
        Cheers man, appreciate the tips!
        Go here be happy!
        Ratchet Garage e30 V8 build.
        • reztat
          • Dec 2010
          • 72
          Thanks for the info, 600 sounds great!
