turbo E30 wont start, pig rich
  • kamotors
    • Nov 2007
    • 7102
    MY turbo build is here http://www.r3vlimited.com/board/show...=225271&page=8
    I've just about finished the E30 but after I installed the 30lb fuel injectors I cant get the car to start. I figured it was running too rich and fouled the plugs so I swapped spark plugs and its still wont run. The plugs I pulled out weren't wet even though my exhaust had black spooge in it. The car did start before the injector swap, I'm running the Miller WAR chip with the turbo base tune specifically for these injectors and a 3.5" MAF.
    horrible video of car trying to start, makes me sad
    7speedshop.com
  • 619E30
    • 1753
    That's strange. Are you running wideband?
    Originally posted by audiquattrot
    bimmers b4 b*tches....remember that.
    1990 Alpinweiss 325i - secret 500whp build
    2000 Audi S4 B5 Laser Red
    1990 Nissan 240sx - Drift Missile
    2006 CBR600RR
    • kamotors
      • Nov 2007
      • 7102
      Not yet hooked up, I'm just trying to get it fired up real quick to make sure all is working. Car wont be driven until wide band is hooked up.
      7speedshop.com
      • AndrewBird
        The Mad Scientist
        • 11897
        Did you check to make sure you are getting fuel/spark? WAR chip come loose slightly?
        • kamotors
          • Nov 2007
          • 7102
          its 100% getting fuel, way too much of it, and seeing as it starts if I keep it floored, it probably has spark. video shows how rich it is.^
          7speedshop.com
          • AndrewBird
            The Mad Scientist
            • 11897
            Ah, sorry. Didn't watch all the way until the end.
            Were the injectors used? Maybe they are leaky? Where did you get the tune you are running?
            • kamotors
              • Nov 2007
              • 7102
              they were rebuilt and flow matched injectors. I got the tune from the forum, I looked at the tune on the computer and all looked fine. Car started with this tune,19lb injectors, and a 2.75" maf, (which its not meant for). Now that I have the correct MAF and injectors the car doesnt run:(
              7speedshop.com
              • einstein57
                • Jun 2007
                • 10780
                I'm pretty sure your ecu goes in to default mode when it does not receive a O2 signal
                www.gecoils.com
                • kamotors
                  • Nov 2007
                  • 7102
                  well, that would explain everything.
                  7speedshop.com
                  • Jafxod
                    • May 2011
                    • 1301
                    badabing
                    Im going megasquirt so Im not even running factory o2 lol
                    • Kvasi
                      • Apr 2011
                      • 1122
                      Sounds like airleak on intake side to me.
                      • kamotors
                        • Nov 2007
                        • 7102
                        discovered my injectors were low impedance, which is likely causing the whole issue. ordering new injectors today. The WAR chip has the option to turn off o2 sensor also.
                        7speedshop.com
                        • AndrewBird
                          The Mad Scientist
                          • 11897
                          You know, I was going to ask that. lol
                          • Zacm829
                            • Jan 2008
                            • 1919
                            Glad you figured it out. I had a similar problem but turned out the be fuel soaked plugs.
                            1987 325i-M60b44 swap
                              • 37828
                              30lb is too big anyway! Get some 24lb in there.
                              Classic BMW Specialists
                              Grover Beach, CA
                              www.BimmerHeads.com
