turbo E30 wont start, pig rich
  • kamotors
    • Nov 2007
    • 7102
    too late I already have the high imp. 30lbers coming in. I can always tune them down a bit with the WAR chip/
    7speedshop.com
      • 37828
      When I first put my car together many many moons ago I tried to run 30lb injectors with Motronic. I could barely get the car around the block. Report back, let me know if it works out for you.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • jaywood
        • Jul 2010
        • 4528
        30lb's work for me. Adjust the afm wheel.
        • kamotors
          • Nov 2007
          • 7102
          I will report back with results, my car doesn't have an AFM.^
          7speedshop.com
          • jaywood
            • Jul 2010
            • 4528
            My bad! Didn't see that.
            My car had the same problem...it wouldn't start when I first put in the new injectors. It took awhile and I had to recharge the battery but eventually it fired up after about 15 tries :(
              • 37828
              And you don't think that's a problem? LOL
              Grover Beach, CA
              www.BimmerHeads.com
              • jaywood
                • Jul 2010
                • 4528
                My battery was almost dead. Brand new injectors. New fuel lines. After it started up the first time it didn't have trouble starting again. So no, I don't think so ;)
                • kamotors
                  • Nov 2007
                  • 7102
                  well, I still haven't received my new injectors even though I paid extra for getting them expedited... But I just read a thread on the other forum that mentioned the TCM dial of the WAR chip not reading the right tune,I ran outside and switched my tune to the #4 position which should of been a tune for 19lb injectors and the car started right up and idled with out me giving it any gas......... it didn't even smoke, as soon as I touched the throttle it died and then my battery died when I tried to restart it. but I'm guessing this means that the TCM was giving the car the wrong tune the whole time:( I still needed new injectors but I'm glad I figured that part out. The thread mentioned position 4 giving tune 1 and it seems to be right on now.
                  7speedshop.com
                  • kamotors
                    • Nov 2007
                    • 7102
                    new injectors fixed it:)
                    7speedshop.com
                    • Zacm829
                      • Jan 2008
                      • 1919
                      Nice, time for a drive!
                      1987 325i-M60b44 swap
                      • brody
                        • Jul 2009
                        • 334
                        Nice you got it sorted. I didn't even know you had problems, remember you can always email for advice.
                        Also to those spreading misinformation, you can run 55# injectors on motronic no problem. 24# is way too small for a turbo application too. If you are talking about running X size injectors working without a tune (a size that is not stock) that's just retarded and you might want to look at hogans goat.
                        • Mr.SWISS
                          • Nov 2005
                          • 1251
                          So I cannot use my 24# gen 3 Ford Racing injectors when I add teh boost?
                          Originally posted by 325Projectz
                          don't listen to the diagram... listen to mr. swiss.
                          :nice:
