ebay 6-2-1 manifold, does it need reinforcing
  • Gruelius
    • Oct 2009
    • 298
    Hey all
    does the ebay 6-2-1 need reinforcing? like a solid bar from the turbo to the flange?
    i got it for about $150 with a bunch of other shit, flange is on right way, ports arent off. they are only having a 1mm lip from the gasket or so but the port on the head is that diameter anyway. just a cheap option. cant use 2-1 here and a tcd is 3/4 a grand landed..
    RIP 84 323i coupe 5spd w/ 14psi
    89' 318i
  • Grand525
    • 491
    What engine is it?
    • The Humjet
      • Jun 2010
      • 528
      He has an m20.
      Being an eBay manifold with the thin stainless steel material. I think bracing it would help prevent crackinng. Iirc dmcl on e30tech braced his 6-2-1 eBay manifold. Check out his thread I think there is a photo showing what he did.
      If you end up deciding to play it safe, drop off the manifold down by my work we should be able brace the manifold for you without much trouble.
      • Gruelius
        • Oct 2009
        • 298
        i cant weld so id be paying someone to do it, and the brace hes got i would have thought the angle of it wouldnt have done much help.
        more just want to know wether it is needed or not, or wether the bracing will help stop the cracking.
        89' 318i
        • downforce22
          • Aug 2009
          • 3192
          mine is the same type and has been braced like dmcl's
          • LowR3V'in
            • 4209
            Brace it.
            I had one crack on me under the turbo flange.
            • blueapplesoda
              • Dec 2005
              • 1904
              I haven't braced mine.... 5 years daily driven, track events and drift events, 45k miles and all. Wouldn't hurt to brace it however, for peace of mind.
              EDIT: Detail I just remembered - I have media blasted the manifold with al oxide, so the peening action might have strengthened the welds and tubes.
              Derek
              DedericMS
